brake lines.
G3GM :: G3 Tech :: Brake Upgrades
brake lines.
Ordered some new brake lines to go with my overhauled rear and of course they don't fit worth a fiddlers f***. I sent them some pics so figured I would post while I'm at it. Last pic is my homemade one I bent buy hand. Hoping to get the rear in this week-end. Left side fit after an hour of tweaking and it's not that great. right side just ain't going to work. I guess I'll stick with my home-made ones. Typical stuff when dealing with a 73~77 a body
73ss- G3GM Enthusiast
Re: brake lines.
I got mine from inlinetube and they fit great. I actually got all the brake lines front to rear from them and they fit good.
Re: brake lines.
Thats where I got mine from. Your right side looks like it lays out good. I think mine is too long. Left side I couldn't get it to fit the outer axle tube clip.
Have you fitted them with the backing plates on?
Re: brake lines.
Yes, rear was blasted, epoxied and installed. Brake lines layed in place, backing plates installed. Then the gears, posi and girdle cover. Lines lined up nicely.
Re: brake lines.
I held the right side next to your pic and I have a S bend that you do not have. Maybe they boxed them wrong.
My girdle cover is on Back order. I'm going to run the old cover for a week or 2, drain it, look things over and then put the girdle cover on.
As always, Thanks for the info...
Re: brake lines.
Joe73 wrote:I got mine from inlinetube and they fit great. I actually got all the brake lines front to rear from them and they fit good.
+1 I bought the complete set of brake lines, front to back, from Inline Tube. I also bought the fuel lines from them too. I didn't have any issues installing any of them.
Hawk03- G3GM Enthusiast
Re: brake lines.
Hey. Funny this was posted. I have been looking at this as I have to do the entire system. I decided to do all of mine from scratch. I just received my brake flare kit in the mail today. I am going to use the NiCopp tubing all new everything. I am doing it this way because I have the Wilwood brake kit with the Wilwood prop valve and master cylinder. For some reason Joe's stuff always looks right.
- Street Cred : 19
» brake lines, brake hoses, prop. valves, brakes, fuel lines...
» New brake lines and fuel line.
» fuel lines
» fuel lines
