front coil springs question
front coil springs question Empty front coil springs question
Post by alive 75 on Sun May 13, 2018 4:00 pm
I want front springs on my monte carlo that will raise the front end up as high as possible any one have the part numbers and the brand to use, thanks
alive 75
alive 75
front coil springs question Empty Re: front coil springs question
Post by Joe73 on Sun May 13, 2018 4:23 pm
Order big block, heavy duty with ac. Stock shocks will top out, at speed with dips in the road. Ride quality will be like a brick. I like it and had it in my car for decades. Same in the rear. Extended shocks would be a good idea. My stock rear shocks could only extend 1 1/2" til they topped out. You will also get lots of wheel hop so run heavy duty shocks. I love the lifted look from back in the day.
Street Cred : 73
Post by thatfnthing on Mon May 14, 2018 12:07 pm
I ran it the same way for a some time, too, though unintentionally. I can tell you it will also destroy your bump stops over time.
Street Cred : 58
