Gear set..nice difference
Post by 1975 S3 on Sat Jun 30, 2018 5:46 am
Just changed gears from 2.73 to 3.42 on a stock 350 4bbl T350 with hooker long tubes and wow! Driveability around town +100%
1975 S3
1975 S3
Re: Gear set..nice difference
Post by Joe73 on Sat Jun 30, 2018 6:23 am
Nice to hear. I always recommend a gear change as a first mod to wake things up.
Street Cred : 72
Post by 1975 S3 on Sat Jun 30, 2018 6:49 am
also on the driveability bit, gear shifter was indefinate and didnt work as it should, tightened it up and works like it should and combined with gear change its a good improvement
1975 S3
1975 S3
Post by bracketchev1221 on Sat Jun 30, 2018 11:15 am
A 1 number change in gears is usually a big difference in driving. My 79 had I think 2.73ís in it and I went to 3.73ís and the car went from 15.20 to 14.12 in back to back weekends at the track.
Post by bigredlaguna on Sat Jun 30, 2018 11:22 am
Does it shift too quick at part throttle for you? Mine did, so I ground some weight off the governor weights to raise the shift points a bit. Adjusting the vacuum modulator just wasn't quite enough.
The downside is that you can spend an entire day just sneaking up on the desired result vs a few keystrokes for a computer controlled transmission.
Street Cred : 53
