Stall when coasting
Stall when coasting
Post by JF74chevelle on Sat Jun 30, 2018 9:11 pm
I have a weird issue. My set up is a Holley 650 DP. Timing is 20 Intial. Idles around 800 rpm. Edelbrock rpm air gap intake with a 2Ē 4 hole carb spacer.
Hereís the problem when Iím driving around 45 mph and downshift to third to slow down then to second and Iím coming down Iíll push in the clutch to coast to the red like but the car goes extremely lean on AFR gauge and the RPMs plummet and I have to tap the gas to keep it from stalling. Iím at a loss. The floats are set right at the bottom of the sight glass. Mix screws are 1 1/2 turns out. Iím confused
JF74chevelle
JF74chevelle
Re: Stall when coasting
Post by Joe73 on Sun Jul 01, 2018 2:30 am
Stock idle rpm for a manual is 900 rpm. So boost that up a bit and see what happens. Also, I never downshift to come to a stop. I don't even clutch it to get it to neutral. If I'm going to stop, I use the brakes like intended. I'd rather change them instead of a throw out bearing or clutch. Just my 2 cents.
Street Cred : 72
Post by BBMALIBU on Wed Jul 04, 2018 11:26 am
JF74chevelle wrote:I have a weird issue. My set up is a Holley 650 DP. Timing is 20 Intial. Idles around 800 rpm. Edelbrock rpm air gap intake with a 2Ē 4 hole carb spacer.
Is the spacer a 4 hole that tapers open or 4 hole from top to bottom?
You can set the float levels a little higher than right at the bottom of the sight glass.
I have mine set 25% up from bottom of sight glass (its also a Pro Systems 1000 cfm).
BBMALIBU
BBMALIBU
