Front Turn Signal/Side Marker Lights
Post by Hawk03 on Sun Jul 01, 2018 1:16 pm
My right front turn signal will not turn on when I turn the lights on. It will work with the turn signal like normal but when I turn on the lights it will not work. Same with the side marker light. It will work with turn signal but not when the lights are on. I checked the ground and installed a new connection on the end of the ground wire but that did not change anything. The left lights work fine with lights on and with the turn signal. Is this a sign of a bad socket?
Street Cred : 13
Re: Front Turn Signal/Side Marker Lights
Post by Mcarlo77 on Sun Jul 01, 2018 6:22 pm
Sure sounds somewhat similar to a problem I was having on the Laguna. Here's the thread if you think there might be some helpful info:
http://www.g3gm.com/t8787-electrical-help-needed?highlight=electrical+problem
Street Cred : 67
Post by Hawk03 on Sun Jul 01, 2018 8:56 pm
Thanks Steve! Your issues sounds excatly like the ones I'm having. I will replace the socket and see if that fixes it.
Street Cred : 13
Post by fasrnur on Mon Jul 02, 2018 3:03 pm
Just last week I finally got around to fixing a similar problem on my car. I traced the wires with a test light and found that al the wires were fine. The park light on the right side would come on just fine, but I had no turn signal up front on the right side. The side marker also would not flash like it's suppose to. I kept after it until I tried running a ground directly from the battery to the outer edge of the light socket and BINGO! Everything worked like it was suppose to. It turned out the socket itself was bad. Ran to NAPA, got a new one, hooked it up and al the lights now work like they're suppose to.
Street Cred : 6
Post by Hawk03 on Mon Jul 02, 2018 9:00 pm
Thanks fasrnur. I just tried a new socket and it seemed to work. I might need to change the whole ground wire though, the wires inside were kind of black and the other wires were just fine. I'm wondering if water got into the wire and worked its way down the wire.
Now on to the other issue. I wanted to install LED lights in the front, I already have them in the rear. When the LED lights are installed in the front turn and side marker lights, the side marker lights do not blink when the lights are on. To get the turn signal to blink with the lights on, I had to switch the two wires coming from the socket (non-ground).
Street Cred : 13
Post by fasrnur on Mon Jul 02, 2018 9:41 pm
I have read that the 194/side marker bulbs are a "one way" bulb? Try flipping them 180 and see if that helps. Not sure if it will, but it sure won't hurt. My ground wire looked the same way. I haven't changed it yet, but I do plan on it in the future.
Street Cred : 6
Post by Hawk03 on Wed Jul 04, 2018 3:07 pm
I installed two new turn signal sockets and that cured the issue. Everything works good with regular bulbs. I bought new side marker plugs as well so I will change those out at some point.
What is the replacement plug for the single headlight? Everything I look at seems to only have 3 wires and the current plug has the wire for the ground to the turn signal.
When I install the LED turn and side marker bulbs they work fine when the turn signal is switched on. But the side marker lights do not come one when I turn the lights on and won't blink when the turn signal is activated if the lights are on.
Street Cred : 13
Post by Dinomyte on Thu Jul 05, 2018 5:28 pm
Hawk03 wrote:Thanks fasrnur. I just tried a new socket and it seemed to work. I might need to change the whole ground wire though, the wires inside were kind of black and the other wires were just fine. I'm wondering if water got into the wire and worked its way down the wire.
LED lights are "one way" or more correctly polarized. You need to have +/- correct unlike an incandescent bulb which just heats a filament and produces light. Good work swapping the wires as that's the fix, if you can't rotate the bulb to do it.
