need some help
alowerlevel
need some help
so i'm 105 miles into my break in period for a brand new posi rear end that was a 2.73 and now is a 3.73 posi rear end.
i went out on a drive ans when i started to do a brake tork the car started to mis fire and then it died out.
it started right up again but when i floored it- it back fired and i blew open both mufflers out surely there is no connection about the engine misfire along with the rear end gear
its a 350 and i have a 3 speed trans, it revs high traveling the highways,
does the high rpms have anything to do with it
thnks Danny
thnks Danny
alive 75- G3GM Member
Re: need some help
alive 75 wrote:so i'm 105 miles into my break in period for a brand new posi rear end that was a 2.73 and now is a 3.73 posi rear end.
thnks Danny
I highly doubt that the rear gears could cause a back fire. Check your plugs and such. Ignition components.
JF74chevelle- G3GM Member
Re: need some help
JF74chevelle wrote:I highly doubt that the rear gears could cause a back fire. Check your plugs and such. Ignition components.
X2, either ignition or a carburetor issue
alowerlevel- G3GM Member
Re: need some help
Has it done it again sine sir? As for the high revs on the highway, you put some steeper gears in it so those will contribute to a higher rpm while driving at highway speeds.
Re: need some help
Sounds like ignition problems. If your car has points and not a hei, i would start there.
Hs1973- G3GM Enthusiast
so this is what happened
a spring popped off the weights under the rotor, and I'm guessing that caused the backfire
I only found this out after I went to the local winners circle and bought new plugs wires cap and rotor and header heat rap
I installed everything, I put the heavy springs in and advanced the timing, I took the car out and ran it a few miles before I laid into it,
I did a nice brake tork and it was perfect did not pop hesitate or misfire, I left a nice 8 foot dual patch of rubber on the back country road,
Re: need some help
alive 75 wrote:a spring popped off the weights under the rotor, and I'm guessing that caused the backfire
Glad you found the problem.
Re: need some help
Laying rubber feels so good. Glad you figured it out.
- Street Cred : 19
» Five Decades?
Yesterday at 8:23 am by Iggy
» 1977 Olds 442 in MN
