Trunk Water Leak
Trunk Water Leak
I have been dormant on this site for some time, as my car sat in storage for the past two years. I have the Malibu back out and driving again. I noticed after getting caught in the rain the left rear trunk well got filled with water. The trunk floor was dry and nothing else seems wet.
Anyone have any ideas where this water would be coming from? My only guess is the back window, but I though the floor would be wet too.
76 Malibu- G3GM Member
Re: Trunk Water Leak
Mine was leaking around the rear quarter glasses and running down. They use a windshield seal and clips hold them in. probably more posts on the subject. Cheers
k-town73ss- G3GM Newbie
I never thought of the side glass. Although my car has the small opera windows. So if they were leaking, I am not sure if they'd go into the trunk well.
Anyone else deal with this problem? What's the best way to find a leak?
My experience in finding waterleaks is to stuff yourself in the trunk with a flashlight, and have somebody hose the car Down while watching from inside where the water comes from. It could could come from a million places. Even a tiny pinhole close to a wheel that is sloshing water around when driving can cause a mess.
Hs1973- G3GM Enthusiast
Thank you for the reply. I will try this out when I wash the car next. I don't think it's from the wheel wells as it leaks worst when its stationary in the rain.
Most of the trunk leaks I've had in the Malibu's and Laguna's I've owned came from the rear glass. The butyl rope sealant that the factory used gets hard and loses its bond with the window. Then the water seeps through and eventual leaks into the trunk area. This was evident on the last car I parted out. When I was removing the rear glass I only cut through the top and the sides of the butyl and the bottom was already free. And of course the trunk was rusted as a result. Fastest way to find if this is the problem on your car is to spray soapy water on the outside bottom of the rear glass. Then take your air hose from a compressor and force air from the inside bottom. If you see bubbles then you have your answer. Hope this helps.
- Street Cred : 33
» Interior Water Leak...
» Trade NOS A-body trunk lid hinges for 1974 Monte Carlo trunk lid hinges.
» oil leak
» oil leak
