'76-'77 Chevelle/El Camino 350 4 barrel OE brackets and plug wire routing
I have a '76 Sprint 350/Q-jet/TH350 (originally 2 barrel) that I am trying convert back to OE throttle cable/detent cable brackets and spark plug wire routing. Needless to say, these items are difficult to locate and even my factory parts/service manuals provide limited guidance.
I believe there's a bracket secured to the rearmost two driver side intake bolts for the detent cable that also supports the 4 wire separator for the plug wires coming off the HEI. The second bracket I believe mounts to the rear carb bolts and reaches over to the driver side to hold the throttle cable coming from the firewall.
Can anyone with an unmolested '76-'77 350/4 setup send me some pics of how all this goes? I'd be interested to see the correct routing for the passenger plug wires as well. I have managed to source a couple tabbed OE valve covers and some of the two wire routing bits from the junkyard thus far.
Thanks in advance.
Thanks in advance.
relic7680- G3GM Member
Re: '76-'77 Chevelle/El Camino 350 4 barrel OE brackets and plug wire routing
My '77 Monte with original setup is put away for the winter...or, else I could take a quick look to confirm. I can confirm for you that the throttle cable bracket does, in fact, bolt to the two rear q-jet carb bolts as you describe. If nobody else is able to step up and help with the other questions, maybe I could dig out the Monte and have a look. Not going to happen before Christmas, however.
Pulled those pieces off a '76 Monte Carlo recently in the Tucson U Pull It. PM if interested in phone pics. Hard to post pics here, doesn't always work.
newmexguy- G3GM Member
Parts
newmexguy wrote:Pulled those pieces off a '76 Monte Carlo recently in the Tucson U Pull It. PM if interested in phone pics. Hard to post pics here, doesn't always work.
I can't get phone pics.....could you try to post them here? Very interested.
relic7680 wrote:newmexguy wrote:Pulled those pieces off a '76 Monte Carlo recently in the Tucson U Pull It. PM if interested in phone pics. Hard to post pics here, doesn't always work.
NEWMEXGUY you can text me the pics and will Host PM me a phone please
» hard to remove 2 wire alt plug, trick?
» Armrest brackets 1973 Chevelle 2 door
» 73 Chevelle SS Fuel Gage Wire or Ribbon Cable?
