Cleaning engine parts
badbiscayne66
I'm starting to tear the engine apart this weekend. What is the best solution for cleaning engine parts? I'm getting a sandblasting booth for Christmas, but as far as home-made chemical cleaning (ie. dropping the parts in a bucket overnight), what do I need? Also, what parts are a must for replacement? I know gaskets, o-rings, and pretty much anything rubber, but is there anything else that needs to be replaced? This is my first rebuild.
Re: Cleaning engine parts
Best thing to do for heads, intake and block is to take it to your car wash and use the soap and power wash the crap out of them. then bring them back home and blow it all out with an air compressor, making sure to get all the passages cleaned out then lube the cylinders and bearing mating surfaces with wd40 or the like.
BlackChevelleSS- Management
If you need any machining done the machine shop can take care of the rest after the car wash.
After getting parts back from the machine shop, you can then do a Dawn soap and garden hose wash to remove any residue that might cause problems upon startup. This is a good time to get a rifle cleaning kit so you can clean out the oil galleys.
Just make sure to oil the cylinders and other internal areas directly after the final rinse
Funny you mention the car wash, because I have one right behind my house. (Like I could literally walk my engine stand right over there.) Thanks for the tips guys.
CASTROL SUPER CLEAN FULL STRENGTH !!!!!!
badbiscayne66- G3GM Member
Back when you could buy paint thinner for 89 cents a gallon I would use that. Now the price is out of sight. JB
The engine internals are fine. I'm just trying to clean 30 years worth of grease and dirt off the outside and repaint it. I've got the oil pan, valve covers, and exhaust mainfold pulled off and was wondering if water does get inside, can I just blow it out with an air hose? I'm leaving the cam shaft and pistons in, so do I have to worry about rust?
put tins back on and you an use any good degreaser just tape off openings
Definitely make sure you don't get any water in places where oil goes. If little specks of rust form, they can get into your oils systems and cause havoc.
IndyG3- G3GM Enthusiast
» Laguna new top and engine parts
» 1974 Monte Carlo engine & engine bay restoration.
» Carburater cleaning
