QA1 Rear Coilovers
QA1 Rear Coilovers Empty QA1 Rear Coilovers
Post by Hawk03 on Mon Feb 25, 2019 9:42 pm
Has anyone installed these? I've read where these might not include all of the hardware but the description says it should include everything.
What spring rate should I use? 170, 200, 220. I'm not going to do anything crazy, I would just like to have some better handling and lower the rear a little. I think the single adjustment should be good for what I want to use them for.
https://www.qa1.net/73-77-gm-abody-rear-pro-coil-system
74malibu383 installed them in 2010 so not sure if anything has changed since then.
http://www.g3gm.com/t2576-rear-coil-over-s
Street Cred : 13
QA1 Rear Coilovers Empty Re: QA1 Rear Coilovers
Post by Hawk03 on Mon Mar 18, 2019 6:22 pm
I bought the rear QA1 coil overs and will be installing them this spring. I will probably do the fronts as well but not sure if they will make the list this year.
Street Cred : 13
Post by g3chevy on Mon Mar 18, 2019 9:19 pm
Nice! What spring rate did you end up going with?
g3chevy
g3chevy
Street Cred : 18
Post by Hawk03 on Tue Mar 19, 2019 9:57 pm
I went with 170. I'm not going to do anything crazy so that should be good for a driver.
Street Cred : 13
Post by Iguy on Wed Mar 20, 2019 1:17 pm
My brother in law has QA1 coilovers all around on his 70 GTO and loves them.  I don't think he had any issues originally but he just went from a 12 bolt to a QP 9" rearend and had to get different mounting brackets because the spring was too close to the axle.
I'll be interested to see how it works for you since I'll probably upgrade at some point down the road.  I went with Viking coilovers up front and they are awesome, I would probably use them for the rear too just to keep it all the same.
Have you weighed your car at all 4 corners to see what spring rate you wanted?  I'm sure ours are similar. I weighed mine last year and was LR 819 lbs, and RR 823 lbs with a spare tire in the trunk and about 5 gallons of gas in the tank.
Iguy
Iguy
