Solid Body Mounts
G3GM :: G3 Tech :: Body
Solid Body Mounts Empty Solid Body Mounts
Post by Curtb on Wed Mar 06, 2019 5:53 pm
Does anyone know were to get solid body mounts? I am looking for them for my 75 Chevelle. Thanks.
Curtb
Solid Body Mounts Empty Re: Solid Body Mounts
Post by fasrnur on Wed Mar 06, 2019 8:22 pm
Not sure where you can find them sir. But unless you're not going to be driving it on the street I would not recommend them. You'll feel every little rock or bump in the road.
Post by bracketchev1221 on Thu Mar 07, 2019 7:36 am
What exactly are you after? There are other options rather than a solid that can work well. And if you are looking for body stiffness, I would look at the frame before body bushings.
Post by Curtb on Sat Mar 09, 2019 11:03 pm
I am building a mostly strip car with a 10 point roll cage that will be welded directly to the frame. So I don't want the body flexing separately from the chassis.
Curtb
Post by bracketchev1221 on Sun Mar 10, 2019 3:12 pm
Poly mounts will be fine.  The cage will stiffen the car up. Make sure the rear bars go down to the upper spring pocket to support it.
Post by Curtb on Wed Mar 13, 2019 11:43 pm
I have not even been able to find a company that makes Polly body mounts that say they will fit my year chevelle. All I have been able to find are rubber replacements from OPGI.
Curtb
Post by Hawk03 on Thu Mar 14, 2019 8:57 pm
I used 68-72 convertible Chevelle mounts. Not sure if they make poly for that gen either but it might be worth a shot.
Street Cred : 13
Post by bracketchev1221 on Thu Mar 14, 2019 10:06 pm
Yes 68-72 has polys.
Post by Curtb on Fri Mar 15, 2019 10:44 am
Thanks for the information. Will any 68-72 mounts work or just the convertible ones?
Curtb
Post by bracketchev1221 on Fri Mar 15, 2019 11:40 am
Count the number of bushings you need and compare them. The only difference between the coupe and convertible was the convertible had 2 extra bushings at the firewall. I just replaced them on my 70 SS and all the bushing holes in the frame are the same size. All the bushings are the same size except the very last 2 in the rear. But if you got them for a convertible, there is a convertible addition kit that gives 2 more.
