1977 Chevelle SE 8-2-19 Motor Updates FINALLY
1977 Chevelle SE 8-2-19 Motor Updates FINALLY   - Page 2 Empty Re: 1977 Chevelle SE 8-2-19 Motor Updates FINALLY
Post by Mcarlo77 on Sun Apr 28, 2019 12:58 pm
Depressing...we escaped that here in Mpls.
Street Cred : 68
Post by Limey SE on Sun Apr 28, 2019 5:40 pm
Swapped some interior for the wheels Today they might look familiar to a certain member here that sold a Maroon Chevelle with a wicked roll cage in it
1977 Chevelle SE 8-2-19 Motor Updates FINALLY   - Page 2 Receiv13
1977 Chevelle SE 8-2-19 Motor Updates FINALLY   - Page 2 20190410
1977 Chevelle SE 8-2-19 Motor Updates FINALLY   - Page 2 54729611
Street Cred : 92
Post by Limey SE on Thu May 09, 2019 9:45 am
So Rods /pistons I got taken on for the 396 Build so started to look again and for what the next set of rods pistons were gonna cost I got the 100% complete 454 from this Motorhome, Hopefully by Sunday will be out
1977 Chevelle SE 8-2-19 Motor Updates FINALLY   - Page 2 56347711
1977 Chevelle SE 8-2-19 Motor Updates FINALLY   - Page 2 59914510
1977 Chevelle SE 8-2-19 Motor Updates FINALLY   - Page 2 59989510
1977 Chevelle SE 8-2-19 Motor Updates FINALLY   - Page 2 57016911
1977 Chevelle SE 8-2-19 Motor Updates FINALLY   - Page 2 59334910
1977 Chevelle SE 8-2-19 Motor Updates FINALLY   - Page 2 59720710
Street Cred : 92
Post by Limey SE on Thu May 09, 2019 10:07 am
Test fitted the Wheels yesterday on there and think they fit very well
1977 Chevelle SE 8-2-19 Motor Updates FINALLY   - Page 2 20190515
1977 Chevelle SE 8-2-19 Motor Updates FINALLY   - Page 2 20190513
1977 Chevelle SE 8-2-19 Motor Updates FINALLY   - Page 2 20190514
Street Cred : 92
Post by thatfnthing on Thu May 09, 2019 1:49 pm
Yes they do!
Street Cred : 58
Post by Limey SE on Sun May 12, 2019 8:51 pm
Well the Nightmare is Finally over I have liberated the Motorhome 454 and transmission I WOULD NEVER RECOMEMNED this LMAO
1977 Chevelle SE 8-2-19 Motor Updates FINALLY   - Page 2 60081410
1977 Chevelle SE 8-2-19 Motor Updates FINALLY   - Page 2 60313810
1977 Chevelle SE 8-2-19 Motor Updates FINALLY   - Page 2 60256810
1977 Chevelle SE 8-2-19 Motor Updates FINALLY   - Page 2 59971811
1977 Chevelle SE 8-2-19 Motor Updates FINALLY   - Page 2 60341610
Street Cred : 92
Post by 73ss on Mon May 13, 2019 5:59 pm
Hey Limey,
If you don't have plans for the Q-jet I'd be interested. $40 plus the ride? If you want to sell, send a pic of the top and the side where the throttle attaches. There should be some numbers running vertically where the throttle is, should be 1708####.
Thanks.
Is that a brake drum on the end of the tranny? Nice score!!
Street Cred : 10
Post by Limey SE on Mon May 13, 2019 6:37 pm
its a Parking brake for the Motorhome
And yes I will be selling the Quadrajet But already have an Offer of $150 for it and motor only has 65k on it so I don't see why it would not be a good carb Just have to remove it and grab some pics for ev1
Street Cred : 92
Post by 73ss on Mon May 13, 2019 8:04 pm
You can't turn that down. I'm sure it will be a good carb. It will have to be re-worked for street use. Motorhome carbs have a odd-ball jet/rod set up because the engine is under constant load in RV.
That's a nice trans also, Heavy duty unit compared to a car one.
Thanks for the reply..
Street Cred : 10
Post by Limey SE on Mon May 13, 2019 9:55 pm
It will be sent with the 4 barrel intake also as I have a better one I will be using instead, and apparently he was blowing smoke up my arse ….. But I will list it for $100 plus ship
Street Cred : 92
Post by Limey SE on Tue May 14, 2019 11:35 pm
Well the 454 is on the stand ready to dive into it YAYYY I don't want to do this again so hopefully all the internals will hold up Only thing I am re using is the Block, Crank, Rods, Pistons everything else will be switched out
1977 Chevelle SE 8-2-19 Motor Updates FINALLY   - Page 2 60803910
Street Cred : 92
Post by thatfnthing on Wed May 15, 2019 10:41 am
If it was intended to survive in a motor home, I have to expect the SE would be almost 'light' duty. Though I suppose that depends on how much your right foot weighs...
Street Cred : 58
Post by Limey SE on Wed May 15, 2019 11:17 am
Heart is light foot is like a rock Just like the Brand I drive LOL
Street Cred : 92
Post by bracketchev1221 on Wed May 15, 2019 11:48 am
The parts in that engine will be fine for a street car. The crank and pistons are most likely cast. I believe the rods in a 1 ton truck would be 7/16” bolt rods.
Post by Limey SE on Thu May 16, 2019 7:54 pm
OK I need a Guru here I have tried looking up these and some people Claim with out a doubt a Peanut port head Then I look up the link they said to look to verify ….It then says its an Oval port Head
OVAL PORT - Valve size 2.06 intake, 1.72 exhaust
14092360 1985-89 454 Open truck
http://www.nastyz28.com/bbcmenu.html?fbclid=IwAR1gfr4MOyZM7iy_rStVIW0SOKwwpgzvlbqppEa88ZKlhkei8pEMXN6CG4g
1977 Chevelle SE 8-2-19 Motor Updates FINALLY   - Page 2 60320410
1977 Chevelle SE 8-2-19 Motor Updates FINALLY   - Page 2 60464910
1977 Chevelle SE 8-2-19 Motor Updates FINALLY   - Page 2 60608110
Street Cred : 92
Post by bigredlaguna on Thu May 16, 2019 9:02 pm
Yup, those are peanut port heads. Nothing wrong with them unless you want to go past 4500 rpm or so.
Cam it up just a bit, or higher ratio rockers on the stock cam. Stock shift points in the trans and 2.73 gears would be the order of the day for these heads.
Here is a pic of 360 head intake ports that is for sale right now on Ebay. You can see the oval port gasket imprint vs the port.
1977 Chevelle SE 8-2-19 Motor Updates FINALLY   - Page 2 360_bi10
Street Cred : 53
Post by Limey SE on Thu May 16, 2019 10:11 pm
Thanks Bobby looks like the 781 Heads are winning this battle pretty easy, will check pistons tomorrow when I pull them
Street Cred : 92
Post by bracketchev1221 on Fri May 17, 2019 7:19 am
Yes they are peanut port heads.  That is all that was available on truck applications.  The large oval port like the 781 went out in the earlier 80's. The pistons will most likely be a flat top piston with a relief for the intake valve. So you will be looking at a low 8:1 compression engine.
Post by Limey SE on Fri May 17, 2019 6:40 pm
Well More tinkering Got Intake, carb off today. Progress is progress
Cam from what I can see of Looks good with no worn lobes, gonna pull pan to verify if 2 or 4 bolt and to put the Car oil pan on it RV pan way to big, Cant wait to clean block and paint it orange Like its supposed be LOL
1977 Chevelle SE 8-2-19 Motor Updates FINALLY   - Page 2 20190518
1977 Chevelle SE 8-2-19 Motor Updates FINALLY   - Page 2 20190516
1977 Chevelle SE 8-2-19 Motor Updates FINALLY   - Page 2 20190517
Street Cred : 92
Post by Limey SE on Thu May 30, 2019 12:10 am
Well finally have all parts picked just need to get them ordered when my parts sell lol
Basic Operating RPM Range: 1,500-5,500
Intake Duration at 050 inch Lift: 224
Exhaust Duration at 050 inch Lift: 234
Duration at 050 inch Lift: 224 int./234 exh.
Advertised Intake Duration: 290
Advertised Exhaust Duration: 300
Advertised Duration: 290 int./300 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.527 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.553 in.
Valve Lift with Factory Rocker Arm Ratio: 0.527 int./0.553 exh.
They Suggested Summit Stage 2 intake but it's the twin to my Edelbrock 2.0 intake, need to gather up a 1700 - 2100 stahl, carb is my quickfuel slayer 725cfm (they suggested going to a 700cfm) so can jet that down I would imagine, my 781 heads had the springs tested and are good to .600 lift so that's good there, he said heads just need a little love from sitting over winter but no worries. So now all the planning is done time to start ripping more into it and get busy.
Street Cred : 92
Post by bracketchev1221 on Thu May 30, 2019 7:49 am
Ok lets see what you got here. As far as I know the edelbrock 2.0 is a twin to the performer intake with the spreadbore pad. The Summit stage 2 is a copy of the original LS-6 aluminum square bore pad intake. The performer type will work, it'll just need an adapter plate to use a square bore holley carb. Overall, the stage 2 would probably make a few more HP on a dyno, but nothing that you would notice seat of the pants. For the carb, just use it. Its not too big. You can't jet it down to be smaller. You can jet it down to change the air/fuel ratio, but it will always be a 725. Also the fact that it is a vacuum secondary carb means the secondaries will actuate based on engine size and vacuum. If it was me, I wouldn't hesitate putting a 750 vacuum secondary carb on a street 454 as the quadrajet that was on it in the motorhome is a 750 at least as well. For the converter, a stock one will work to get you going, but if you are looking to upgrade, go for a 2-2400 converter. 17-21 is too close to stock, that it would probably function as a stock converter behind a mild engine.
Post by Limey SE on Thu May 30, 2019 7:13 pm
These are the Edelbrock 2.0 and the Summit Stage 2 So Ray I am glad someone stepped up about what stock size might be, I have searched until my fingers hurt and voice crackled
1977 Chevelle SE 8-2-19 Motor Updates FINALLY   - Page 2 Edl-2110<---Edelrbrock 2.0
1977 Chevelle SE 8-2-19 Motor Updates FINALLY   - Page 2 S-l30010<---Summit Stage 2
Street Cred : 92
Post by Joe73 on Fri May 31, 2019 12:26 pm
That summit stage 2 definitely has an open pleunum unlike the dual plane of the edelbrock. I'd go edelbrock for the street if I had to choose between the two.
Street Cred : 73
Post by 73ss on Fri May 31, 2019 5:24 pm
My 2cents FWIW:
If you have not purchased yet, Try to find the thinnest, smallest bore head gasket you can find for you'r bore size. Fel-Pro blues are thick. Cometic has a nice selection, but pricey at about $100 a piece. You need all the help you can get for compression.
Street Cred : 10
Post by bracketchev1221 on Fri May 31, 2019 6:32 pm
Joe73 wrote:That summit stage 2 definitely has an  open pleunum unlike the dual plane of the edelbrock.  I'd go edelbrock for the street if I had to choose between the two.
It’s a dual plane with the divider milled. Just like the performer rpm air gap manifolds. Gm knew that milling the divider was worth power 40 years ago on the big blocks. But I agree for this application it’s not really necessary.
