Stainless brake hose
Is anyone running a stainless brake hose to the caliper? If so what brand? I’m looking into doing some front brake upgrade.
JF74chevelle- G3GM Member
Re: Stainless brake hose
I'm using Earls.
If I recall , I bought them through Summit.
Also , I have a B-body front end upgrade assembly available. Spindles , calipers , rotors all one piece. Unbolt your upper / lower ball joint and tie rod end....slide these in....bleed the brakes. Your in business.
impalamonte- G3GM Enthusiast
Pretty sure I have Earl's as well, but it's been so damned long that I don't 100% remember.
I'm right there with you "thatfnthing".....
I would have to go to my receipts.....
