spring start up
spring start up Empty spring start up
Post by 73ss on Wed Apr 10, 2019 6:52 pm
spring start up Dscf2710
A spring start up tip. Guys running a mechanical pump, I take a diff lube nozzle and place it in the carb vent (perfect fit, no spills) Slowly pour gas down the nozzle (an ounce or 2) and fill the carb bowl. 2 or 3 pumps of the pedal and my car starts immediately. The car will stay running long enough without stalling because the float bowl is full. If you just pour some gas down the intake it will just stall out after a few seconds because the bowl will be empty until the fuel pump can catch up.
This will avoid excessive cranking on a dry cam & lifters after sitting all winter. This will work on other makes of carbs as well as long as the vent tube empties into the float bowl.
Street Cred : 10
spring start up Empty Re: spring start up
Post by Joe73 on Wed Apr 10, 2019 7:02 pm
Excellent tip !!!!!
Street Cred : 73
Post by 73ss on Wed Apr 10, 2019 7:20 pm
Thank You!!
Street Cred : 10
Post by Limey SE on Wed Apr 10, 2019 7:50 pm
You have been stickied LMAO Darn glue anyways
spring start up 12527912
Street Cred : 92
Post by g3chevy on Fri Apr 12, 2019 11:43 am
You just saved me wasting about a gallon of gasoline this year lol.
g3chevy
g3chevy
Street Cred : 18
