Steering box upgrades
What steering box upgrades do you guys run. I know people run the Jeep Grand Cherokee boxes with good success. I want tighter feel with more feedback, steering feels really reactive but it doesn’t feel heavy enough.
JF74chevelle- G3GM Member
Re: Steering box upgrades
86 Monte Carlo SS. 2.5 turns lock to lock.
73ss- G3GM Enthusiast
73ss wrote:86 Monte Carlo SS. 2.5 turns lock to lock.
Is it pretty much bolt in?
Would this one work
https://www.summitracing.com/parts/ado-36g0104/year/1986/make/chevrolet/model/monte-carlo
Yes it's a direct bolt in as far as to the frame and the pitt-man arm.
The lines are O ring, You'll need to use adapters or change the pressure fitting at the back of the pump over to O ring style, and use a O ring style pressure line. Return line You'll need to grab the line fitting from a donor car, The rest is hose clamps.
I can't remember what I used for the rag joint. It's been about 15 years now. You'll need to find one for the late model splines on the input shaft to mate to the old style column. I think I used one from a 80's square body pick-up.
The one you show looks like it's for the standard monte. The SS boxes have the feel you are looking for. I think someone has a link on the forum here with the different boxes. I think 80's z-28's also use the same box.
There is more than just lock to lock for the "feel". You also can change how much pressure the pump puts out. Pirate 4x4 has a lot of information about boosting pump pressure that you can also use to decrease the pressure.
There is also some internal calibrations in the steering gear that regulates how much torque is required before the pump pressure is even used. Most people won't care to get into the box for this, but the information is out there if you care to look into it.
bigredlaguna wrote:There is more than just lock to lock for the "feel". You also can change how much pressure the pump puts out. Pirate 4x4 has a lot of information about boosting pump pressure that you can also use to decrease the pressure.
Is it on the forum? I wouldn’t mind “tuning” on the box to see if I can get it feeling better without spending big money.
There isn't a dedicated thread on this forum that I'm aware of. The pump pressure information is easy to find, but the gear box info is limited. I only found it because I got nerdy about this stuff a few years back.
My basic recollection is there is a particular part known as a torque rod IIRC, that is the tuning point in the box. The larger diameter rod needs more torque input from the steering wheel before allowing pressure assist from the pump.
Our boxes, of course, would have the smallest diameter torque rod. The Monte box has a slightly larger one. IIRC, the police car boxes from the 90's had the largest rods, but didn't always have the lock to lock ratio. I can't confirm this at all right now, and I didn't save any links from when I did all this research, but if you search along those parameters you should be able to find what I found.
My .02 cents....
Look at page 4 of my post.
May help in making a decision on what direction you want your upgrade to go.
https://www.g3gm.com/t8709p75-update-1973-monte-carlo-body-off-frame-resto
impalamonte- G3GM Enthusiast
