Starter Wire tube heat shield
Starter Wire tube heat shield Empty Starter Wire tube heat shield
Post by Joe73 on Sun Sep 08, 2019 6:42 pm
Im looking to install the factory Heat shield tube for the starter wires. Anyone have any pics on how it mounts to the trans bolts? Its kind of bent like an "L" so I figure the other end of it must go to a bolt on the starter itself.
Any pics out there? Thanks in advance.
Street Cred : 75
Starter Wire tube heat shield Empty Re: Starter Wire tube heat shield
Post by g3chevy on Sun Sep 08, 2019 11:12 pm
Joe, is this the part you're referring to? If so, the mounting tab with the small hole attaches to one of the solenoid mounting bolts and the other should attached to the transmission to engine mounting bolt that is the second one up from the bottom. Let me know if you need a pic and I'll take a pic for you tomorrow when I'm over at the shop.
Starter Wire tube heat shield Starte10
g3chevy
g3chevy
Street Cred : 19
Post by Joe73 on Mon Sep 09, 2019 7:00 am
Yes, that's the tube. I figured it went to a solenoid bolt. I put a mini starter in the car so I guess I won't be using the tube. I'll heat sleeve the wires. Thanks for the help.
Street Cred : 75
