Horns?
Page 2 of 2 Previous  1, 2
Re: Horns?
Post by 77malibu77 on Sun May 16, 2010 4:06 pm
no but i have taken the steering column apart many times to change cancelling cam, turn signal housing, and some other little parts from the malibu column
but it never worked ever since ive gotten it the first time ive ever heard it go off was yesterday but only twice
or are you talking about turning the steering wheel? no i didnt all i did was connect the green wires and turned on the car and pressed the horn pad
does there have to be a ground on the horn or something all i have is a green wire that goes to the first horn in the drivers fender then connects to the other horn behind the grille
77malibu77
77malibu77
Street Cred : 6
Re: Horns?
Post by ant7377 on Sun May 16, 2010 7:10 pm
The big bracket the actual horn is mounted on is the ground.
Street Cred : 35
Re: Horns?
Post by 77malibu77 on Sun May 16, 2010 7:13 pm
oh ok lol so then theres just the green wire
77malibu77
77malibu77
Street Cred : 6
Re: Horns?
Post by dragons_lair59 on Sun May 16, 2010 8:03 pm
not sure if i have 1 or 2 horns but mine sound like a freaking freight train
Sam
Managment
Managment
Re: Horns?
Post by 77malibu77 on Mon May 17, 2010 5:34 pm
AL;RIGHT so i just embarresed tha crap out of my self
i had to get my friend a jump and right when i pulled up my horn just started going off for no reason and i pressed the horn pad and it didnt go off SOOOO embarrassing
what caused this???
77malibu77
77malibu77
Street Cred : 6
Re: Horns?
Post by 1973 454 MONTE on Mon May 17, 2010 5:51 pm
77malibu77 wrote:AL;RIGHT so i just embarresed tha crap out of my self
what caused this???
the operator Razz Razz Razz Razz Razz Razz Razz Razz Razz Razz Razz Laughing
Street Cred : 35
Re: Horns?
Post by 1973 454 MONTE on Mon May 17, 2010 5:54 pm
i have the dual horn wiring,but only have one horn Head Bang
i guess i need to get another horn on there scratch ,but it already sounds like a semi-horn with just the one.
affraid
Street Cred : 35
Re: Horns?
Post by 77malibu77 on Mon May 17, 2010 6:11 pm
what are you talking about?
lol now i have my horns disconnected but if i connect them they are going to go off what is causing this
77malibu77
77malibu77
Street Cred : 6
Re: Horns?
Post by 1973 454 MONTE on Mon May 17, 2010 6:35 pm
77malibu77 wrote:what are you talking about?
either the relay is stuck,or you pad is touching.
Street Cred : 35
Re: Horns?
Post by 77malibu77 on Tue May 18, 2010 1:22 am
k idk what the pad could be touching but i guess i will look
77malibu77
77malibu77
Street Cred : 6
Re: Horns?
Post by ant7377 on Tue May 18, 2010 5:26 pm
Chris where is the horn relay on the77?
Street Cred : 35
Re: Horns?
Post by 77malibu77 on Wed May 19, 2010 1:08 am
it should be under the dash little box connected to a wire and the plug end looks like this -_-
77malibu77
77malibu77
Street Cred : 6
Re: Horns?
