A pillar trim??
G3GM :: G3 Tech :: Body
Page 1 of 2 1, 2  Next
A pillar trim??
Post by alowerlevel on Fri Dec 18, 2009 1:41 am
I was lookin at my 73 the other day and noticed that on the a-pillar there is what looks like a trim piece that runs from the vinyl top down the a-pillar. It has a grain on it to match the vinyl on the roof, my question is what am I supposed to do with that when I get rid of the vinyl top? I dont know whats under it, is there a different trim piece for a non-vinyl topped car?? All I know is I wanna get rid of the damned top before it makes the roof any worse and Im gonna keep it off. Also what about the 1/4 window, winshield & rear window trim? Is it different between the two tops? Ive seen some cars without any trim on the 1/4 windows, so does that mean I can leave them off (I kinda like the way they look without them) and not worry about water leaks etc??? Sorry bout the long post and all the questions but Im still new to the G3's and I wanna get everything in order so I can try fix most of it this winter.
Thanks
alowerlevel
Street Cred: 1
View user profile
Re: A pillar trim??
Post by JB2wheeler on Fri Dec 18, 2009 5:31 am
Dont be sorry, we are here for your support. I am just sorry that I, personally, can not help you but someone here will be able to answer your question. JB
Street Cred: 21
View user profile
Re: A pillar trim??
Post by IndyG3 on Fri Dec 18, 2009 6:40 am
I might be able to help! Very Happy
If you want to get rid of your vinyl top permanently, the A pillar trim (the steel pieces molded to look like vinyl) will be removed because the top will be smooth, and so should the A pillars. You may also want to fill int the screw holes that held the pieces in place (I don't know if all models had this piece held in with screws, it's just how mine is).
As for the 1/4 winidows, you could take off that trim if you want to. Just make sure the windows themselves are installed properly and they shouldn't leak.
I think when you pull off the rear window trim there will be some holes left over that you'll have to fill in. Nothing too major, just some holes used to keep the trim in place.
I'm not sure about the front.... and It would probably be best to get someone else here to verify my ranting, but I hope this helps...
IndyG3
Street Cred: 11
View user profile
Re: A pillar trim??
Post by bigredlaguna on Fri Dec 18, 2009 8:09 am
As far as the quarter window goes, I've seen the bottom edge filled in with clear silicone so there is no chance of water sitting between the glass and the metal. There was a car I saw in a junkyard that from the doors back was practically brand new that had this treatment.
Street Cred: 31
View user profile
Re: A pillar trim??
Post by Limey SE on Fri Dec 18, 2009 9:53 am
I know the opera and triangle window trim have different thickness to allow for the vinyl roof material to sit in there, and the clips for the trim I do believe will have to be ground off for the trim for the vinyl top, alot of people I have seen just leave the trim and paint the roof half the color of what the vinyl top would have been
Street Cred: 60
View user profile
Re: A pillar trim??
Post by alowerlevel on Fri Dec 18, 2009 5:57 pm
Thanks for the help and info guys. Ill have to look more into the a pillar trim and how to remove it as I didnt see any screws (I didnt look all that well though).
alowerlevel
Street Cred: 1
View user profile
Re: A pillar trim??
Post by alowerlevel on Fri Dec 18, 2009 6:03 pm
Heres the A pillar trim Im worried about (in case I didnt describe it right) Its the piece inbetween the winshield trim and the driprail trim.
alowerlevel
Street Cred: 1
View user profile
Re: A pillar trim??
Post by Limey SE on Fri Dec 18, 2009 6:11 pm
they are not screws they are clips in the trim it self the clips are on back side of trip be very full when you remove them not to damage them........there is a tool they have for that but the name escapes me at the moment I will look in my books I have
for I have seen it there
Street Cred: 60
View user profile
Re: A pillar trim??
Post by alowerlevel on Fri Dec 18, 2009 6:15 pm
Thanks that would be great if you could find the name of that tool. And the pillar will just have holes in it for the clips and thats it? It will be smooth and all I have to do it weld the holes up? Thanks again
alowerlevel
Street Cred: 1
View user profile
Re: A pillar trim??
Post by Limey SE on Fri Dec 18, 2009 6:16 pm
molding clip remover page 615 of OPGI catalog so yo have pic to know what you are looking for at parts store
Street Cred: 60
View user profile
Re: A pillar trim??
Post by Limey SE on Fri Dec 18, 2009 6:17 pm
the stud for the clip should be welded to body let me find a reference pic ( will be rear) but you will see what I mean
Street Cred: 60
View user profile
Re: A pillar trim??
Post by 1973 454 MONTE on Fri Dec 18, 2009 6:18 pm
Limey wrote:molding clip remover page 615 of OPGI catalog so yo have pic to know what you are looking for at parts store
you can buy the tool at a auto parts store.
2012 Donating Member
Street Cred: 26
View user profile
Re: A pillar trim??
Post by 1973 454 MONTE on Fri Dec 18, 2009 6:19 pm
alowerlevel wrote:Heres the A pillar trim Im worried about (in case I didnt describe it right) Its the piece inbetween the winshield trim and the driprail trim.
under the rubber there are screws that hold all 3 pieces on.((black chanel,chrome,pillar piece)
peal back the rubber carefully
you will see a black chanel,you should see screw heads.
might be 3 or 4 of them,cant'remember.
hope this helps.
Street Cred: 26
View user profile
Re: A pillar trim??
Post by alowerlevel on Fri Dec 18, 2009 6:21 pm
Oh if thats all it is Ive got atleast one of them here some where. So it should just pop off and thats it? Thanks for answering my questions, Im still new to the G3's and dont want to screw anything up cause parts for these arent exactly plentiful around here. If this was a 64-72 car Id be done already, lol.
alowerlevel
Street Cred: 1
View user profile
Re: A pillar trim??
Post by alowerlevel on Fri Dec 18, 2009 6:23 pm
1973 454 MONTE wrote:under the rubber there are screws that hold all 3 pieces on.((black chanel,chrome,pillar piece)
hope this helps.
Thanks alot Ill have to look at it tomorrow.
alowerlevel
Street Cred: 1
View user profile
