rear drum to disc conversion
Page 1 of 3 • Share •
Page 1 of 3 • 1, 2, 3
where is the best place to get a conversion kit to change the rear to disc from drum?
jegs has it for $699 and i saw one somewhere else for $899 and one for $1299 but cant remember where they were.
- Street Cred: 8
Re: rear drum to disc conversion
buy a whole caprice and take alot more parts than just the disc brake conversion !!!!!!!!!!
- Street Cred: 60
what year?
- Street Cred: 8
92 IS THE BEST YEAR I HERE BUT I THINK 92 TO 96 IS THE ONES THAT ARE SO SIMILAR
- Street Cred: 60
99ish 2wd blazer at a junk yard or something... Will have to make some spacers and maybe turn down the outside of the axles a small bit.
- Street Cred: 13
what do you mean turn down the axles?
- Street Cred: 8
The outside of the axles where the lug studs are is too big around for the inside of the blazer disk. I have not confirmed this but its what ive heard. I have a blazer rear and front disk setup that im gonna try and swap on sometime.
- Street Cred: 13
Try speedway. A lit of dirt trackers use our cars/chassis and I think there are a number of bolt on coversions. In the $300 range too.
jonny o- G3GM Member
- Street Cred: 2
NPD, has a large range of prices and kits for the rear drum to disc conversion. I bought the best one they had it was around $1,200. That came with cross drilled rotors, and red painted calipers. It is a true bolt on! the cheaper kits might not have everything you need...but it wouldnt hurt to call Summit or Jegs to ask.
Cdub74- G3GM Member
- Street Cred: 0
Maybe a moot point, but why rear disc brakes? My Malibu stops fine with 9.5 " drums in the back. They can be converted to 11" easily also, like the '76 and '77 El Camino has.
pila- 2012 Donating Member
- Street Cred: 17
I agree. Its your front brakes that work the hardest. JBpila wrote:Maybe a moot point, but why rear disc brakes? My Malibu stops fine with 9.5 " drums in the back. They can be converted to 11" easily also, like the '76 and '77 El Camino has.
- Street Cred: 21
also the 75 76 Laguna came with 11" drums
- Street Cred: 60
probably just out of convenience...i HATE drums
- Street Cred: 6
They're not too bad to work on if you go buy a drum brake spring removal tool. I bought one for $10 when I rebuilt the drums on ranger literally came apart. Anyone else had that happen to them?
Malicruiser- G3GM Member
- Street Cred: 6
I realize that many new cars have discs all around. I do wonder if disc brakes are less expensive to put on the new cars, as opposed to the drum system. The mfgrs usually figure out a way to save a few bucks when producing cars. Quite a few less moving parts in a disc system, and easy to install and replace etc.
If working on your own brakes, a few tools to do it are sure cheap compared to having it done at a shop. And the spray-cans of brake cleaner really work good to clean the crap off when working on drum brakes.
- Street Cred: 17
Similar topics» Help on gls to gti conversion
» Promoting Disc Golf May 19 -20
» Ace Eagle Disc Golf May Schedule
» Ream for rear swing arm
» REAR DISK BRAKE SET RM450
Page 1 of 3
» Wallys 73 Malibu project
» Quarter windows
» 1973 CHEVELLE SS 454
» what a truck!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
» window sweep
» Rochester, NY
» for you monte guys. 1/64 diecast. i will keep adding
» have got a lead on parts
» ROTW
