grant quick release hub
what quick release do i need?
they have a few that i know it cant be but i dont know what ones it is out of these.
:Pinless Quick Steering Wheel Disconnect Kit, Weld-On Hub For 3/4'' Shaft, Fits Grant Steering Wheel w/ 3 Hole Bolt Pattern
:Pin Type Quick Steering Wheel Disconnect Kit, GM Splined Shaft, Fits Grant Steering Wheel w/ 3 Hole Bolt Pattern
:Pinless Quick Steering Wheel Disconnect Kit, GM Splined Shaft, Fits Grant Steering Wheel w/ 3 Hole Bolt Pattern
:Pinless Quick Steering Wheel Disconnect Kit, Weld-On Hub For 5/8'' Shaft, Fits Grant Steering Wheel w/ 3 Hole Bolt Pattern
http://www.jegs.com/p/Grant/Grant-Quick-Release-Hubs/748405/10002/-1
- Street Cred: 8
Re: grant quick release hub
was going to get this kit but i dont know if it will fit
http://www.jegs.com/i/Grant/470/673K/10001/-1
- Street Cred: 8
I have a non-tilt colunm but might get tilt someday. i took off my wheel and its 3 small bolts and a large nut in the center.
- Street Cred: 8
corey if its saveable i can hook you up with limeys tilt column floor shift steering column
- Street Cred: 60
470-3001 is what I would get if I were looking to get one of those.
A lot of these are weld on application, so once you install it you pretty much can't go back very easily.
bigredlaguna- G3GM Enthusiast
- Street Cred: 31
Limey wrote:corey if its saveable i can hook you up with limeys tilt column floor shift steering column
not right now. im going to get it running and the floor shifter and seats in then see where im at. im getting a little ahead of myself if i get anything right now besides seats, and shifter
- Street Cred: 8
Similar topics» D1 Spec Quick Release Hub
» Grant Holt submits a transfer request
» Say a quick hello
» grant quick release hub
» AE86 Steering wheel w/ Quick release and hub
» Say a quick hello
» Wallys 73 Malibu project
» Quarter windows
» 1973 CHEVELLE SS 454
» what a truck!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
» window sweep
» Rochester, NY
» for you monte guys. 1/64 diecast. i will keep adding
» have got a lead on parts
