Gear drive vs Timing Chain
Page 3 of 3 • Share •
Page 3 of 3 • 1, 2, 3
Re: Gear drive vs Timing Chain
It was what they used from the factory. I just helped my dad tear apart a 327 a couple of months ago & the Nylon gear was still in good shape even though the chain showed stretching.
Ive got a collection of them, My dads 302 in his 69 camaro has nylon gear originally in it and it blew up.
One weird thing I noticed the other day, We ordered a Cloyes True Roller with thrust bearing and the cam gear has the GM logo and GM part number on it, the crank gear was billet steel with 3 key ways
BlackChevelleSS- Management
i think they have a gm part number because they use them in soe gmpp engines
Sam
dragons_lair59- Managment
My nylon gear in my 351W dumped at 99,000 miles. I caught it just in time to stop any other damage, I was lucky. JB
i know im a couple years late but back to the orig. question. the gear drive can cause harmonics and catastrophic faliure to your cam if it is not installed properly. i have seen broken cams from this. yes it is more accurate on cam timing which in turn would give you more horsepower over a chain of any type. common sence if there is no slack there is no lag, no lag = quicker responce. quicker responce= more power. all chains have some slack. on a gear drive there is slack also but it is 0.020 max if set up corectly. a chain is up to .25 max.
robert_harsh101- G3GM Newbie
Page 3 of 3
» For Sale: '74/'75 Pontiac Lemans Front Chin Spoiler
» Auxiliary transmission cooler orientation.
» 1974 Laguna Front End
» PARTING OUT 1973 GTO & 1973 Grand Am
» Aluminum Water neck
» Rear sway bar brackets
» I have some auctions
» Hello from Florida!
» Last Nights MOTORWEEK on Velocity Channel : 1975 Laguna
