need help with trunk seal
need help figuring out how to put trunk seal on my 1974 cutlass my car did not have a old seal to use for refference so i have no idea how this should go lol
74442guy- 2010 Donating Member
- Street Cred: 0
Re: need help with trunk seal
Start it in the middle nearest the trunk lock opening, add an adhesive around the edge (some guys don' think adhesive is necessary-DUH) work the weatherstripping around to where it fits well, not too tight not too loose, go all the way around til the ends meet, check the fit, check it again, then cut off the excess. Close the old trunk lid and give the adhesive plenty of time to dry before opening the trunk. I don't know if your car has a "channel", but if so you may need something flat (a spoon works , believe it or not) to work the weatherstripping into it.
Not hard, but if the fit is too loose or too tight, you'll be doing it again very soon. DON"T open the trunk too soon or you'll pull it loose if it sticks.
Last edited by Roadcaptain S3 on Thu Mar 04, 2010 1:53 pm; edited 2 times in total
Roadcaptain S3- 2010 Donating Member
- Street Cred: 10
ok thanks forall the help iwill try not toget it toloose or to tight lol
- Street Cred: 0
Old credit car or plastic scraper works good too for pushing the rubber in the channel
ant7377- G3GM Senior Member
- Street Cred: 12
I've found that masking tape is helpful in the corners too. Sometimes they pull up.
74Malibu383- G3GM Enthusiast
- Street Cred: 20
Similar topics» Transmission oil seal leak
» Trunk Leaks
» help with ghia door rubber seal
» SB TRUNK (check it out)
» Clutch pushrod oil seal
» Trunk Leaks
» Wallys 73 Malibu project
» Quarter windows
» 1973 CHEVELLE SS 454
» what a truck!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
» window sweep
» Rochester, NY
» for you monte guys. 1/64 diecast. i will keep adding
» have got a lead on parts
