i really hate electrical
G3GM :: G3 Tech :: Electrical
Page 2 of 3 • Share •
Page 2 of 3 •
1, 2, 3
Re: i really hate electrical
Knew it !
Same thing I did they were touching because I wasnt careful,live and learn.
ant7377- G3GM Enthusiast
- Street Cred: 9
I can blame my dad for this one.
he hooked it up the first time, Problem was the power wasnt to the solinoid but right to the starter on on of the smaller nuts holding the cover togeher.
made good progress today though fixed that then while my dad did the plug wires i got the grant wheel fitted corectly, the steering colunm tighteded up, mirror on, and mos of the wiring and the lights hooked up and eveerything is good so far ecept one more problem....
Left turn signal is stuck on even when the key is off and the right one dosent work! im getting all new fuses tomorrow. any idea what this cuase is?
- Street Cred: 8
Check that none of the wires down on the column are stripped and touching
at that big connector that mounts on the column it self.
- Street Cred: 9
and another ?,,i told you i dont know electrical! lol
What kind/size fuse's do i need under the dash? the ones directly in the fuse panel they all look old and are all glass. are they 15amp?
- Street Cred: 8
Some are .Do you have a owners manual? It will tell you right in there.
If not check in a Chilton manual most GM cars from that time would be the same.
- Street Cred: 9
OK got new fuese under the dash all in. charged the battery turned it over just to see if the starter would click and the GEN light comes on and my amp guage goes flatline and not a single click..though that battery was just whoa nelly but i tried a newer battery that had a full charged and it does the same thing. so i think the starter might still be wrong somehow? any thoughts?
- Street Cred: 8
- Street Cred: 8
I know how this sounds, But get under the car with a BFH and whack the
he)) out of the starter a few times then try it again. Sometomes they will freeze up after sitting, and a couple of good whacks might break it loose. A hundred and thirty three years ago, when my 74s starter was going bad, i carried a steel pole in the trunk just to knock the piss out of the starter 'til i could get a new one, worked then. probably work now.
Really old trick that usually works , believe it or not. Sounds and looks like everything else is hooked up properly. Good job not dropping an F-bomb in the vid too.
I'm figuring at this point it's your starter or solenoid. Coulda got screwed up w/the electrical gremlins.
Or i could be a complete looney.
Roadcaptain S3- 2010 Donating Member
- Street Cred: 10
yea my sister been having to hit her starter too haha. my starter is all new never used though but it could be stuck ill hit it with a rubber mallet and try agian
- Street Cred: 8
What about the solenoid? Did you get a new one w/ the starter?
- Street Cred: 10
coreys73chevelle wrote:yea my sister been having to hit her starter too haha. my starter is all new never used though but it could be stuck ill hit it with a rubber mallet and try agian
Didnt work
- Street Cred: 8
Roadcaptain S3 wrote:What about the solenoid? Did you get a new one w/ the starter?
yes new with starter.
- Street Cred: 8
so i get one of these right?
http://www.opgi.com/product.asp?catmainid=1&topcatid=4&chapterid=4&grpcode=10635&ProdCode=PP00033&yearrange=#thumb
ive had my dash and column totaly apart before BUT not to the switch HOW the heck are you supoosed to get past the part where the wheel mounts? is there a special tool i can maybe rent from autozone?
- Street Cred: 8
yep sppecial tool if i remember right and should be a pin and or clip that has to be removed also
- Street Cred: 7
coreys73chevelle wrote:so i get one of these right?
its called a lock plate remover should be around 15 bucks to rent from autozone and if you rent it you can pay the 15 and use the tool then bring it back the same day and get your money back
- Street Cred: 6
Page 2 of 3 •
1, 2, 3
Similar topics» Electrical prob??? not sure
» Posi-Lock electrical connectors
» I hate me job,
» So you hate Paypal
» i fucken hate KFC group
» I hate me job,
Page 2 of 3
» 1976 laguna budget protouring build
» MSD boxes/any ignition box mounting
» Here we go laguna clone pro touring build begining phase
» Newbie here
» Sprucing up my 77' G3 with 77' vette wheels
» Ultimate Automotive Motion Picture
» Dash woodgrain
» 400 SBC for sale Kentucky
» 1977 Chevelle SE 6 days and counting
