Suspension Parts
Page 1 of 1 • Share •
Suspension Parts
Rear springs for a 68-72 chevelle and 1996 impala ss rear springs will also fit 1973-77 Chevelle
- Street Cred: 8
Re: Suspension Parts
Double check your info. I know from personal experience that they are shorter. Here's a great post from another member that can explain much better:
Posts from another member:
One of my older posts talking about the old 76:
Take it for what it's worth......
bigredlaguna wrote:I wish the companies that sold lowering springs put the stats of their springs up so I can compare them to stock, but here is a little bit of info that I compiled from the NAPA site for stock springs.
1970 coupe/sedan rear springs
Free Height= 14.71" Spring rate= 119 lbs/in.
1974 coupe/sedan rear springs
Free Height= 15.82" Spring rate= 137 lbs/in.
Station Wagon rear springs are the same for all years (?) I only compared 70 to 73-77
Free height= 14.34" Spring rate= 198 lbs/in.
Using the weight of 74Malibu383's car from a different post, the ride height using these spring rates works out like this.
weight on rear wheels= 1803 lbs / 2 = 901.5 per side
divide 901.5 by the spring rate to get the compression distance of the spring.
1974 spring
901.5/137=6.58" of compression
Then subtract the compression distance from the free height to get the compressed height of the spring.
15.82-6.58=9.24"
The average load height(compressed height) is 9" +/- 0.5 for stock ride height.
Now using 1970 coupe/sedan spring info
14.71-7.57= 7.14"
So a stock spring from a 70 will get you approximately 2" of drop. The downside is that it is a much softer spring and you will bottom out too easily.
Front springs do not interchange. The inside diameter of a 2nd gen spring is 3.68" while a 3rd gen ranges from 4.04 to4.09
novaderrik wrote:i also have the rear springs out of the 92 9C1 in my Monte- perfect fit, but it did jack it up some (which is what i wanted to clear the slots).
novaderrik wrote:when i wanted to jack up the back of my Monte to clear the 275/60's on the slots, i put in the rear springs i had kept out of the 92 Caprice cop car i had parted out. they boosted the rear of the car up about an inch or so and gave it just the perfect 70's poser rake without giving up any ride quality or handling like air shocks do.
station wagon springs are also good for this, as well.
Rago wrote:OK. I don't normally recommend JCW, but I had these on my 76 for a couple of years. Because they were designed for earlier models to lift 3-4", they only lift ours 1-2". At least it did mine. This isn't because of the weight difference, but because G3s have longer rear springs. I still have them lying around somewhere I might post pics if I can find them. They will definitely stiffen up your ride & make great drag springs IMO:
http://www.jcwhitney.com/COIL-SPRINGS/GP_2005875_N_111+1971+200728448+600003409_10101.jcw
I don't know about springs for the front, but the rears worked great.
- Street Cred: 48
I have 96 caprice springs in my 77 Monte .Dosent really lift it much .
If you want to lift it get them from a 76 Caprice but the ride will be hard.
ant7377- G3GM Senior Member
- Street Cred: 12
BUT ride hight will be changedcoreys73chevelle wrote:Rear springs for a 68-72 chevelle and 1996 impala ss rear springs will also fit 1973-77 Chevelle
- Street Cred: 8
Suspension related: I see that one company that makes tubular a-arms lists the same part number for 73-77 Chevelles/Monte, 75-79 Nova, 70-81 Camaro...does that sound right??
FormulaZR- G3GM Member
- Street Cred: 0
http://www.g3gm.com/t1030-the-interchangability-thread
http://www.g3gm.com/t627-73-firebird-camaro-suspension-same-as-73-77-a-body-maybe
^^^Yep.
Also The Astro/Safari van is the same with larger ball joints as well as the 77+ Caprices. Didn't know about Novas being the same though.
^^^Yep.
- Street Cred: 48
Similar topics» Thanks Wayne for the Suspension up grade.
» Invicta Parts
» -Spidel Parts-
» marinising parts
» Moped parts
» Invicta Parts
» -Spidel Parts-
» marinising parts
» Moped parts
» Quarter windows
» what a truck!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
» window sweep
» Rochester, NY
» for you monte guys. 1/64 diecast. i will keep adding
» have got a lead on parts
» ROTW
» 74 Buick Regal
» 1975 Laguna For Sale
