Rear control arms
Rear control arms
just wondering why the factory didnt completely box the control arms on the f41 suspension like they did on the earlier chevelles. Instead they got some bracket bolted to them that the sway bar mounts to. Anyone completely boxed the control arms? Thinking about doing so to strengthen them up when they get pulled to put in the poly bushings. Also does it use the same bushings as the earlier chevelles in the arms? Cause I was thinking of ordering a whole kit and installing the polys in the lowers only and in the lowers on my 70.
BlackChevelleSS- Management
Re: Rear control arms
Boxing them helps quite a bit. If you have any extra cash lying around, get some Edelbrocks. I like them. JB
ill probably just box in the stockers and install poly bushings, and put in a set of adjustable uppers.
