rust hole repair
G3GM :: G3 Tech :: Body
rust hole repair
Post by coreys73chevelle on Fri May 28, 2010 2:14 pm
what would you guys do about this? NOT BONDO! lol, either a lower 1/4 panel replacement or a patch panel? i can get a local body shop to come out to my house and patch it for $250-$300. or ill just replace the whole thing and thats about double.
[img][/img]
[img][/img]
coreys73chevelle
Street Cred: 8
View user profile
Re: rust hole repair
Post by coreys73chevelle on Fri May 28, 2010 2:21 pm
im thinking about replacing it. new front floor pans plus new 1/4 panels on both sides?
http://www.opgi.com/product.asp?ProdCode=1667163&grpcode=10729&topcatid=26
coreys73chevelle
Street Cred: 8
View user profile
Post by 77malibu77 on Fri May 28, 2010 3:23 pm
honestly corey i wouldnt bu\y the whole quarter panel unless its rusty on the bottom of the quarters behind the back wheels
what you could do is get a thin piece of sheet metal and put it over the rusty hole and shape it the best you can to where all sides will be welded on clean (not rusty) metal, then when it is perfect you can cut out the old rust and put the new one on there with sheet metal screws until you can get ahold of a welder, look up how to repair rust holes and youll learn theres no point in buying the whole quarter
i am your age and even i wouldnt do that
77malibu77
Street Cred: 6
View user profile
Post by ant7377 on Fri May 28, 2010 3:27 pm
Why not try to find another in a junkyard and cut that section out a bit bigger then weld it onto yours.
Street Cred: 9
View user profile
Post by coreys73chevelle on Fri May 28, 2010 3:46 pm
ant7377 wrote:Why not try to find another in a junkyard and cut that section out a bit bigger then weld it onto yours.
nope ive searched the junkyars here, they get picked to fast never seena g3 velle only a few elkys and they are usually rusted to crap Sad
coreys73chevelle
Street Cred: 8
View user profile
Post by 74MonteCarlo on Fri May 28, 2010 4:32 pm
There are NO classic cars in the junkyards around my house...
Street Cred: 16
View user profile
Post by 77malibu77 on Fri May 28, 2010 4:59 pm
well the section your looking for is also on a elky lol so see if you can find one or something
there was someone on here that was working on that 77 impala or something and he repaired the rust down there and behind the wheels one of you guys know what im talking about
i think the title of the post was 77 impala coupe or something its white
77malibu77
Street Cred: 6
View user profile
Post by 77malibu77 on Fri May 28, 2010 5:03 pm
here it is look at all the pictures and stuff the guy tells you how to repair it i am going to have a lot of work to do on my malibu so i feel your pain lol
http://www.g3gm.com/g3-project-pictures-f10/1977-impala-coupe-rescue-t1952-15.htm
77malibu77
Street Cred: 6
View user profile
Post by coreys73chevelle on Fri May 28, 2010 8:04 pm
thanks, ill probobly use that
coreys73chevelle
Street Cred: 8
View user profile
