Drive Shaft length
Page 1 of 1 • Share •
Drive Shaft length
Anyone know the length of the driveshaft for a 73 with a TH400 short tail trans?
BlackChevelleSS- Management
Re: Drive Shaft length
i don't have a spec, but it's the same as a TH350.
novaderrik- G3GM Member
if its the same i can measure mine later
mine is 59" and 3/4" from end to end including the shaft
TH400 is longer than a th350 so it has a shorter driveshaft.
the factory 454/TH400 parts car i got a few years ago had the exact same driveshaft that is in my TH350 car, but with the bigger TH400 yoke. i only found out that they were the same because i wanted to use the TH400 shaft with my TH350 yoke when i did the 700r4 swap, but when i set it next to my existing shaft, it was the same length.
We measured 53" ctc with the rear suspension loaded and the yoke 1" pulled out. Dont know how long the th350 driveshaft was...
» For Sale: '74/'75 Pontiac Lemans Front Chin Spoiler
» Auxiliary transmission cooler orientation.
» 1974 Laguna Front End
» PARTING OUT 1973 GTO & 1973 Grand Am
» Aluminum Water neck
» Rear sway bar brackets
» I have some auctions
» Hello from Florida!
» Last Nights MOTORWEEK on Velocity Channel : 1975 Laguna
