ball joint bolt torque?
Page 1 of 2 • Share •
anybody know what to torque the replacement balljoint bolts too because im drawing a blank
billy-ray- G3GM Enthusiast
- Street Cred: 13
Re: ball joint bolt torque?
theres a torque???????
i just ate my weaties and tightened all i could.
- Street Cred: 26
TIGHT
- Street Cred: 13
Tighten till you pop a vein in your forehead, LMAO!
- Street Cred: 48
Rago wrote:Tighten till you pop a vein in your forehead, LMAO!
- Street Cred: 6
Take it to the jackwagons that did an(emergency) oil change for me once! Took me 10 f-ing minutes to crack the drain plug loose the next time I changed it! I wanted to go back and shoot those c*ck juggling thunder c*nts for putting it on so damn tight!!!!!!!!!
[/anger and rant]
[/anger and rant]
- Street Cred: 16
74MonteCarlo wrote:Take it to the jackwagons that did an(emergency) oil change for me once! Took me 10 f-ing minutes to crack the drain plug loose the next time I changed it! I wanted to go back and shoot those c*ck juggling thunder c*nts for putting it on so damn tight!!!!!!!!!![]()
[/anger and rant]
No offense, but that's what you get for letting someone else touch your pride and joy.
74Malibu383- G3GM Enthusiast
- Street Cred: 20
It wasn't the 74 Monte. It was the 98, and its NOT my pride and joy. It was an 'emergency' change, if you will. I was 70 miles away from home at my grandma's place for the week, I was a hair over 3000 miles since the last change, and something told me to check the oil when I got there, and it was very low. Didn't want to drive home with it that low.
- Street Cred: 16
So... you couldn't have put a half/full quart in it? I don't think 70 miles + (a hair over 3K) constitutes an "emergency" change.
But hey, to each their own.
- Street Cred: 20
billy-ray wrote:anybody know what to torque the replacement balljoint bolts too because im drawing a blank
From another forum - Says it's from the 74 manual.....
Ball Joint Studs: Upper-60# .. Lower 83#
Upper control arm to frame: 97#
Upper control arm shaft nuts: 68#
Shock absorbers: 90# (inch/lbs)
Stabilizer bar link: 150# (inch/lbs)
Stabilizer bracket: 24#
Disk Brake Caliper: 35#
Link:
http://www.elcaminocentral.com/showthread.php?t=25692
- Street Cred: 20
I don't like to go over 3000. Mainly becasue it has aloud rod knock when it's cold and I want to take care of it to make it last as long as I can.
Go a head and read my signature again if you don't like how I maintain MY car.
- Street Cred: 16
its a 98 all its good for is dumping bleach in and enjoying the show
- Street Cred: 13
Maybe to you, but I like it. I don't get on your A$$ for your car.
- Street Cred: 16
Similar topics» BIG BOY BALL!!!
» 8-Ball revenge !!!
» Ball - Fireman Night Train
» OK, I WANNA KNOW..........JIM'S SALARY.........JUST GIVE ME A BALL PARK
» Removing Ball Joints on a Polaris Sportsman
Page 1 of 2
» Just some pics
» ~~Introduce Yourself~~
» Wallys 73 Malibu project
» window sweep
» 75 cutlass cheap
» 73' Chevelle (Malibu) Interior Plastics
» NO...NO...NO...
» 75 cutlass
