progress
progress
well the engine and trans are in! kickdown hooked up and some wiring. ill get pics later
Re: progress
ever get that bumper figured out?
BlackChevelleSS- Management
Re: progress
no, im going to have my dad help so i can have someone hold it while another adjusts it
Re: progress
What are the specs on the engine if you dont mind me asking? Get any more pictures yet?
JasonZ- G3GM Member
Re: progress
what specs do you want?
i have no pictures yet my camera is messed up.
cam is a hydrolic roller for a 350hp/327ci and is 222dur/447lift
crank is for 350 but polished and balanced
pistons are 10 over cast 10:1 compression
roller rockers and more
Re: progress
coreys73chevelle wrote:what specs do you want?
Mainly heads if you dont mind saying. As I want to get Pro Toplines Stage 3s 64cc, angled plugs, 200cc intake would be nice if they can be CNC Machined. But I'm running fuel injection so might be a little different with me running your style heads.
JasonZ- G3GM Member
Re: progress
i will tell you anything you need to know, all i know is by measuring the valves they are 2.02/ 1.60s, they are cast iron, but im not sure about the brand, the casting numbers had been ground smooth before i got the car.
if i had to guess they are GM performance?? but i dont know
Re: progress
got some more done. throttle cable, radiator hoses and cusions, and water neck and thermostat.
flatend a old throttle bracket to put under the new one and it isnt even visable and it is stronger and lines up way better.
[img][/img]
[img][/img]
also twisted the mount for the transmission dipstick to mount on firewall it wouldnt fit to the intake manifold
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
Re: progress
looking sweet corey ..........gettin anxious arent you??
Re: progress
yea, but it looks like ill be ready for opening day at the track on march 1st
Re: progress
BREAK THAT MOTOR IN FIRST BRO OR IT WILL BREAK ON YOU
Re: progress
oh yea, i will ill get a good 8-10 hours on it i know i wont get a lot of miles on it before then. thats what my friend used to have them do with his motors when he was in the NHRA when they built them for him they would run it for 8 hours total at varisous rpms and then ship it to him and itd be ready to run 9s.
Re: progress
if i feel like its not broken in by then i wont run it
Re: progress
That dipstick mounted to firewall might break or pull out of trans whrn motor torques over ........Just keep an eye on it!!
badbiscayne66- G3GM Member
Re: progress
badbiscayne66 wrote:That dipstick mounted to firewall might break or pull out of trans whrn motor torques over ........Just keep an eye on it!!
Thats exactly what I was gonna say.
Re: progress
hayden high performance transmission cooler
[img][/img]
[img][/img]
Re: progress
got the throttle cable and Kickdown routed and working, and (GOON and HYDRO) i DID NOT drill the hole just cut it and left it like it is in the 2nd pic on page 1 of this topic, thats what my neighbor sayed they do with the cars at work, hes a master mechanic sayed itll be fine, i was only going to cut a hone in the floor so it would be hidden more out of the firewall not cut a hole in the firewall.
Re: progress
also pluged the water pump and manifold becuase my heater doesnt work anyway so im just going to take it out.
Re: progress
cool, you gonna run stainless braided line to the cooler or hardline?
Re: progress
kewl we were wondering why you gonna cut a hole for that ....but you left before i actually knew what you were talking about ,,,,but glad you figured it out
Re: progress
not sure yet, thinking ill use stainless
Re: progress
homemade faceplate for toggle switches from a sill nosing.
not done yet still need to put choke cable in and get wiring.
[img][/img][img][/img][img][/img]
