Frame to body mounts?
Post by Laguna Budman on Tue Aug 31, 2010 8:40 pm
Anybody know who makes them. Underbody is lined and ready to go on frame but want to get new mounts. Everything else is new so don't want to stop now. Any help would be appreciated.
Street Cred: 4
View user profile
Re: Frame to body mounts?
Post by 77malibu77 on Tue Aug 31, 2010 9:44 pm
heres the bushings
http://www.elcaminostore.com/el-camino-body-mount-bushings-1973-1978.html
and heres the bolts for it
http://www.elcaminostore.com/el-camino-body-mount-bolt-kit-1973-1977.html
77malibu77
Street Cred: 6
View user profile
Post by Laguna Budman on Tue Aug 31, 2010 9:54 pm
Thanks dude, gettin ready to order them! Much appreciated
Street Cred: 4
View user profile
Post by billy-ray on Tue Aug 31, 2010 9:54 pm
energy suspension sells a whole kit for 250 every bushing you need in polyeurothane prothane sells a kit for 161.99
http://www.jegs.com/i/Prothane/311/7-2004-BL/10002/-1
billy-ray
Street Cred: 13
View user profile
Post by moneypit16 on Tue Jun 28, 2011 9:14 pm
how many body mount bushings come in the prothane kit? i was thinking of replacing the 4 cushions with regular mounts, i haven't been able to find any kit that comes with the cushions so i was just planning on using regular mounts... don't really know why they didnt do that in the first place... but anyways i need to find a kit with 14 mounts, anyone know anything?
moneypit16
Street Cred: 0
View user profile
Post by 73CopperMonte on Sat Nov 26, 2011 9:34 pm
I bought the poly set for a 96 Caprice 9c1, since the B-body frame is very similar to our 73-77 A-body. When I pull the body off the 73 I will compare the bushings for everyones info. Scott
73CopperMonte
Street Cred: 1
View user profile
Post by pila on Sat Nov 26, 2011 9:43 pm
The Parts Place has the stock type mount bushings for A bodies. That's where I bought mine. Decent price too.....
2012 Donating Member
Street Cred: 17
View user profile
body bushings
Post by 2fat2fly on Sun Nov 27, 2011 12:32 am
73CopperMonte wrote: I bought the poly set for a 96 Caprice 9c1, since the B-body frame is very similar to our 73-77 A-body. When I pull the body off the 73 I will compare the bushings for everyones info. Scott
It would be great to have someone actually see if the early Caprice even come close http://www.thirdgen. http://www.thirdgen. http://www.thirdgen.
2fat2fly
Street Cred: 0
View user profile
Post by pila on Sun Nov 27, 2011 4:57 pm
I should mention that someone on another forum bought some mounts that didn't come with the metal bushings. Not easy to locate the metal bushings separately, so, a word to the wise......make sure you get mounts with the bushings Smile
Street Cred: 17
View user profile
Post by wokrdan AKA BU Balls on Sun Nov 27, 2011 5:08 pm
Just so you know, if you upgrade to the polyurethane, the original bushings do not fit.
Street Cred: 2
View user profile
Post by pila on Sun Nov 27, 2011 6:18 pm
That's good to know. One thing for sure, the poly bushings will last longer than rubber.
Only negative I've seen discussed about the poly bushings is that there's no give in them, for slight frame-to-body differences, like the rubber type have.
Street Cred: 17
View user profile
Post by 2fat2fly on Sun Nov 27, 2011 8:39 pm
pila wrote:That's good to know. One thing for sure, the poly bushings will last longer than rubber.
I have heard that the ride is a bit harsher you tend to feel everything ?????????????????? not sure but it does make since
2fat2fly
Street Cred: 0
View user profile
