dropping ideas
+8
77malibu77
coreys73chevelle
74 chevelle malibu
12 posters
Page 1 of 3
Page 1 of 3 • 1, 2, 3
dropping ideas
I been looking at lowering spring or front spindles and was wondering which is better. if use front spindles how is the rear lowered? i want 2 lower whole car but want what handles the best.
74 chevelle malibu- G3GM Member
Re: dropping ideas
spindles are better for best get both, fatmanfab has them both for decent prices thats what i want. rear is lowered by lowering springs
Re: dropping ideas
Thanks I also found Qa1 has adjustable coilover kit for these cars and thinking that may be best.
Re: dropping ideas
74 chevelle malibu wrote:Thanks I also found Qa1 has adjustable coilover kit for these cars and thinking that may be best.
yea the fatman kit come with the Qa1's
Re: dropping ideas
whats the cheap way to lower the front?? cheap but strong
Re: dropping ideas
If you're looking for cheap, then get a new set of factoryreplacement springs and cut them down. Or, you can get a set of lowering springs that have a firmer spring rate. It depends on what kind of ride qualtiy you want.
IndyG3- G3GM Enthusiast
Re: dropping ideas
can i just cut the ones that i have in there now?
Re: dropping ideas
Of course you can. New is optional. I only say to use new springs because older ones sag a little bit and might not give you a decent ride quality once you cut them.
Re: dropping ideas
Get a set of springs for a 6 cylinder car with no AC on it and cut off one coil. That way you will not have as harsh a ride as with the heavier springs. JB
Re: dropping ideas
ill see. how much would new lowering springs run me im kinda tired of how it feels when i drive on a bumpy road
Re: dropping ideas
or maybe ill just keep the same springs but get drop spindles? which would be cheaper?
of course if you look in my default you can see something needs to be done, the front is way to high up. thanks guys
Re: dropping ideas
Drop spindles might mess up your suspension geometry. New springs are about 100 bucks for a pair, and the lowering ones like what I have where about 20 dollars more for each pair. Either way shouldn't be too expensive if you know what to look for.
Re: dropping ideas
IndyG3 wrote:Drop spindles might mess up your suspension geometry. New springs are about 100 bucks for a pair, and the lowering ones like what I have where about 20 dollars more for each pair. Either way shouldn't be too expensive if you know what to look for.
which ones did you go with? kinda like how your car sits. and did you get the 2 inch drop springs?
Re: dropping ideas
http://www.summitracing.com/parts/GLS-S-14/
Those are the fronts that I got. They've gone up in price a little bit since I bought mine though. I will say that they do work very well on the car...it sits right, and the ride isn't bad at all.
Re: dropping ideas
Put a big block in it and it will lower itseld
BlackChevelleSS- Management
Re: dropping ideas
BlackChevelleSS wrote:Put a big block in it and it will lower itseld
lol!
and how come those springs are only 1 inch lowering springs? i at least want 2 or 3
Re: dropping ideas
They do have diferent lowering rate springs. Those were the first ones that came up for me. All of that stuff should be on Summit. You also need to remember that the number that they show is an average and doesn't really factor in spring sag.
Re: dropping ideas
oh alright man thanks alot gave you street cred!
Re: dropping ideas
How would drop spindles mess with suspension geometry? Springs would affect it more than spindles. Drop spindles are the same physical size as factory most of the time with only the spindle itself being moved upwards. Dropped springs are going to be shorter & stiffer. Spindles are always the preferred method if you choose to keep factory ride quality. With springs, an alignment is going to be required, spring travel will be reduced, probably have to either change or adjust bump stops as well. On our cars it's not like we are limited with travel, but just something to think about when debating between the two.
Re: dropping ideas
Adjustable QA1 coil-overs - Get you whatever ride height you want. Of course, you do need to have it alligned, but they work awesome. 1000 times better than cutting the springs (I know from experience).
74Malibu383- Donating Member
Re: dropping ideas
ive pretty much ruled out cutting the springs and am leaning toward drop spindles. would love to have coil overs but thats a little too much money.
Re: dropping ideas
What do you think you're going to spend on drop spindles???
Re: dropping ideas
i dont have access to any type of welder lol.
Page 1 of 3
