9" 73-77 GM A-Body Bolt-In Housing
Post by Limey SE on Mon Sep 20, 2010 11:18 pm
http://www.quickperformance.com/Products/housings.htm#Axles
$745 Complete w/ Axles, Axle Bearings, Studs, & Retainers
- $365 Housing Only (Brackets Installed)
- ADD $30 for Moser Axles
Fits: 73-77 GM Chevelle, Monte Carlo, Cutlass
* Adjustable Lower Brackets Available +$30
* Custom Made To Order - Any Length
* Choice of Housing Ends (1/2") - (3/8" New Style)
* Drain & Fill Plugs w/ Jack Pad + $55
* Billet 10/12 Bolt GM Housing Ends + $75
* Heavy Walled Tubing + $30
* Back Brace Installed + $169 (Sold Separately $69)
9" Furd QP Extreme Series Axles
$300 Per Pair
Axle Bearings, 1/2" Studs, & Retainers + $125
+ $20 - A-20 Tapered Bearings
+ $20 - 5/8" Coarse Studs
* Thick 1/2" Flange Provides Extra Strength
* 5 on 5, 5 on 4-3/4", & 5 on 4-1/2" Bolt Patterns
* Drilled for .685" Press In Studs
* Increased Material In Normally Weak Areas
* STRONGEST AXLE ON THE MARKET!!!!
Available In 28, 31, & 35 Spline!!!
Lengths Available
(C-Dimensions):
Up to 34-1/2"
(Per Axle)
9" Furd Custom Alloy Moser Axles
$330 Per Pair
(28 - 31 - 33 - 35 Spline)
Axles, Bearings, Studs, & Retainers + $125
+ $65 - 5/8" Drag Studs
+ $100 - 40 Spline Axles
+ $100 - Gun-Drilling (33-35-40 Spline Only)
+ $50 - Star (Scallop) Flanges
+ $40 - Lighten Axle Flanges (Round Holes)
+ $20 - Access Hole
* Ideal for Street, Strip, & Circle Track Applications
* Custom Made For Any Application
* Any Lengths Available
Street Cred: 60
View user profile
