Spark Plug Recomendations for HEI
badbiscayne66
coreys73chevelle
Oidar
I've got a NEW HEI distributor from eBay and I want to put in fresh plugs when I change it out.
I know there are different plugs for a '74 (point ignition) and '75 (HEI) so do I just tell them it's a '75 at the parts counter?
Also, is there a particular brand / type that's best? I've heard people say those split-fire jobs are good.
My engine is the original (sleepy) 350 2bbl. Compression is good on 7, but 1 is a little soft. Probably getting some blow-by on that one so I'm concerned about fouling.
Oidar- Donating Member
Re: Spark Plug Recomendations for HEI
my nieghbor is a master mechanic he reccomended ACCEL brand
anything that is a platnium or titanium is a good one brand doesnt matter to much as long as they are titanium or platnium
I think those fancy plugs are a waste of money!! I use regular old AC!!
badbiscayne66- G3GM Member
ac has a platnium and thats what i use in both our cars and have NEVER had a prob hers is a cavalier and mine well you know what it is LMAO
If you are getting blowby, I highly recommend going with an NGK. It's the only thing that will still fire when it's really really gunked up.
Just tell your parts guy to crossreference your current plug to the same NGK v-groove plug and you will not be disappointed.
You can open up the gaps a little further with the HEI, but I think the heat range will be about the same depending on how gunked up the chambers are. Maybe start with a 32-35 gap.
Next time you need to add oil, add a quart of ATF and run it normal for a few days. Next oil change, add a quart of Lucas Oil Stabilizer (not synthetic). It will help you out with those rings.
jonny o- G3GM Member
e3 diamond fires work great, you can get them at autozone and kragens little expensive but worth it
McCauley5983- G3GM Enthusiast
just get the stock plugs for your car- AC R45TS, most likely. open the gaps up to about .045 or so and screw them in.
novaderrik- G3GM Member
