Rear sway bar mounting
Page 1 of 2 • Share •
Does anyone have any pictures they can send me or post showing how exactly the rear sway bar mounts to the lower control arms? My car never had one from the factory, but I picked a used one up with the...two "U" channels that each have four mounting bolts in them. Any pics sooner the better would be very helpful. Thanks guys.
A_Tame76- G3GM Member
- Street Cred: 0
Re: Rear sway bar mounting
HEY BUDDY they just slide right into the lower control arm check my post I just put one on there
- Street Cred: 60
where is your post? If there was a photo in your reply...I dont see it or it isnt displaying.
- Street Cred: 0
let me link I dont have an actual pic while I was under car but I can grab one tomorrow and show ya, but it does show the parts I used and they only bolt up one way and your control arm MUST have the provision for the sway bar already or wont work........
- Street Cred: 60
If the sway bar has the bolt holes in vertical orientation, there should also be a U-bracket that fits inside the LCA for the bar to bolt to.
bigredlaguna- G3GM Enthusiast
- Street Cred: 31
well...my car didnt have a rear bar originally....thats why I wanted to see what one looked like. Im hoping I can use it still. And I have the U channels for either side too.
- Street Cred: 0
A_TAME76 see how the bolt holes are offset that is how they go into LCA
well sway bar is in and was a perfect fit with the NIB brackets and the sway bar from the caprice 9C1 police package from mid 90's, if you get new brackets remember to hang onto the 8 self tapping bolts you will need them for the new bracket for the side holes are not threaded and you have to run the bolts in before mounting the brackets to thread them..............
OLD SWAY BAR
NEW SWAY BAR BIG DIFFERENCE
OLD SWAY BAR
- Street Cred: 60
and On a side note you can buy them brackets for the sway bar mounting from GM parts direct 8.95 a side NIB
@ A_TAME76 I will snap a pic in morning for you if thats kewl
- Street Cred: 60
I wish I had a photo looking up at the lower control arm with the sway bar into it. I used to have a few of these pics, but now I cant find them.
- Street Cred: 0
you will have tomorrow buddy come back in morning after 9 am
- Street Cred: 60
in this pic the top of this is actually the bottom if that makes sense ??
- Street Cred: 60
yup....makes perfect sense.
I just had my old 350 trans takin outta the car and had a new built up 400 put in. Also took out the 3500 stall and had a 12" 2500 stall in it from a 70 LS-6 car. The 3500 stall had a TON of slip in it and wasn't right for the big block. The old stall worked when I used to have the small block in it. Have a Hurst Pistol grip shifter in it now.
- Street Cred: 0
sweet and where is the Project up date from that would like to see it ??
- Street Cred: 60
when I get the car back...Ill update it. Its in right now for some rear end work, was gonna drop off the sway bar in the am...thats why I was asking about the pics of the mounting setup.
- Street Cred: 0
so are these sway bars factory? I know there factory on caddies. I want to add one to the mali.
orange Juiced- 2010 Donating Member
- Street Cred: 6
Similar topics» Chevy Rear-end Wanted
» REAR DISK BRAKE SET RM450
» Swing-arm & rear shock linkage maintenance
» what is 1/4 inch square hole in rear fenders for?
» EVO UPGRADED BRAKE KIT REAR - USE WITH 17x8J ET25 TOMBINOS
Page 1 of 2
» Just some pics
» 76 S3 in Franklin Indiana
» 4L80E..Reduced...$300
» ~~Introduce Yourself~~
» Wallys 73 Malibu project
» window sweep
» 75 cutlass cheap
