Engine ground strap
G3GM :: G3 Tech :: Electrical
Page 2 of 2 • Share •
Page 2 of 2 •
1, 2
Re: Engine ground strap
in front of the engine under the alt,should be 2 threaded holes (air pump).just bolt the cable to there and the other end could go to an already threaded hole in the frame (like the pos battery clamp).
1973montec- G3GM Member
- Street Cred: 6
Page 2 of 2 •
1, 2
Similar topics» CONVERTING FROM 6-VOLT POSITIVE GROUND TO 12-VOLT NEGATIVE GROUND
» ridinfool strap on the DW!
» Gold bearing ground?
» Coil choice - Shallow Ground
» 4G93 NA ENGINE
» 4G93 NA ENGINE
Page 2 of 2
» Just some pics
» 76 S3 in Franklin Indiana
» 4L80E..Reduced...$300
» ~~Introduce Yourself~~
» Wallys 73 Malibu project
» window sweep
» 75 cutlass cheap
