Front brake upgrade?
Page 1 of 2 1, 2  Next
Post by JiMi_DRiX on Mon Nov 01, 2010 10:25 pm
I need to replace the rotors on the front of the Monte, are there any brake upgrades that can be done? Aside from the thousand dollar type BAER or Wilwood type parts? I just want some slotted or drilled rotors, something different, or better. Brakes and suspension are kind of out of my know-how..
Street Cred: 1
View user profile
Re: Front brake upgrade?
Post by The Dude on Tue Nov 02, 2010 8:03 am
Here's a combo package for the front. Only $215 for it all:
http://www.summitracing.com/parts/SSB-A2350012/
Cheapest two piston calipers that I've found. Comes with pads, but it's $415....
http://www.summitracing.com/parts/SUM-BK185S/
I'm sure there's more out there since 70-81 Camaros & 77-9? Caprices use the same set up. Possibly some 94-96 police package brakes or Impala SS would be an upgrade? Not positive though.
Street Cred: 48
View user profile
Post by Limey SE on Tue Nov 02, 2010 9:44 am
but remember if you go with caprices your bolt pattern might have to be 5 x 5 on the later yeared ones IE the SS version style
Street Cred: 60
View user profile
Post by BlackChevelleSS on Tue Nov 02, 2010 10:19 am
EBC rotors can get slotted and green stuff pads
Street Cred: 13
View user profile
Post by pila on Tue Nov 02, 2010 1:57 pm
I haven't heard how good the stainless brake rotors work (?) A lot of rotors will warp a bit with a panic high speed stop.
2012 Donating Member
Street Cred: 17
View user profile
Post by JiMi_DRiX on Tue Nov 02, 2010 7:53 pm
That rotor/pad upgrade from Summit looks like the same one PST has, and its about the same price as well. I dont drive the car a lot anymore, so having some nice brakes would look good and last me a long time. I am real big on quality though, I know there are lots of fancy cheap stuff on eBay, but I'd rather not go near that stuff!
Street Cred: 1
View user profile
Post by pila on Tue Nov 02, 2010 11:33 pm
Good thought. In my opinion, brakes are too important to use cheap parts on. At least the stainless rotors wont rust when a car sits around or in storage.
Street Cred: 17
View user profile
Post by JiMi_DRiX on Wed Nov 03, 2010 12:30 am
I think I'm going to price a set of good OEM rotors and pads, and compare prices. Does anyone think the stopping power would be any bit significantly different between stock OEM and those slotted rotors? 355+hp might need a little extra stopping power...
Street Cred: 1
View user profile
Post by BlackChevelleSS on Wed Nov 03, 2010 12:55 am
its not the horsepower but the weight of the ships we all drive. I doubt youd notice a difference between oem and slotted rotors, but the brake pads make a big difference. Also an adjustable proportioning valve would be a good upgrade to get the braking between front and rear where it needs to be.
Street Cred: 13
View user profile
Post by The Dude on Wed Nov 03, 2010 8:30 am
The slots are actually just for cooling it down. If you like to brake hard & often, then that's the way to go. If you drive like an old lady, then it isn't going to make a difference. The major things you will notice are good pads like Black said & also upgraded calipers.
Not sure if these would work, but I'm hoping to use them on mine if they do. 4 piston Wilwood calipers for $125 each. Someone wanna help out on this one? Jegs has it listed to fit 69-84 GM in their book. Summit is just an easier site to navigate, but says they are universal.
http://www.summitracing.com/parts/WIL-120-6818/Application/?prefilter=0
Street Cred: 48
View user profile
Post by The Dude on Wed Nov 03, 2010 8:31 am
Limey wrote:but remember if you go with caprices your bolt pattern might have to be 5 x 5 on the later yeared ones IE the SS version style
I meant calipers, not rotors.
Street Cred: 48
View user profile
Post by JiMi_DRiX on Wed Nov 03, 2010 10:56 am
Yeah, true. The Land-Yacht of a Monte Carlo is a little heavy and hard on the brakes.. I dont know how mine have warped, twice... maybe slotted rotors would help with the cooling some and prevent it from happening again? Or its just this pair of rotors are crap. Those Wilwood calipers are nice! Little upgrades like that also add the cosmetic changes that really clean up the car too. Has anyone swapped their rear drums for discs?
Street Cred: 1
View user profile
Post by Bill's 74 on Wed Nov 03, 2010 11:09 am
From what I understand....
If the wheels are properly torqued, the pads and rotors are 'seated-in' properly when new, and after a panic stop you release the brakes as soon as you can, you will reduce the chances of warping rotors.
Bill
Bill's 74
Street Cred: 2
View user profile
Post by The Dude on Wed Nov 03, 2010 12:06 pm
Cheapest & easiest drum to disc swap is the Impala SS/late model Caprice rear as far as I know. Direct bolt in, but you get stuck with 5x5 bolt pattern instead of the 5x4.75 that we have. Main thing to remember here is to buy a proportioning valve if you go this route.
I believe there is a write up on this somewhere. I'll look around.
Street Cred: 48
View user profile
Post by Bill's 74 on Wed Nov 03, 2010 12:19 pm
Rago wrote:Cheapest & easiest drum to disc swap is the Impala SS/late model Caprice rear as far as I know. Direct bolt in, but you get stuck with 5x5 bolt pattern instead of the 5x4.75 that we have. Main thing to remember here is to buy a proportioning valve if you go this route.
Rears I assume?
Yes, The P/V and a 4 wheel disc Master too.
Bill
Bill's 74
Street Cred: 2
View user profile
