door hinges
G3GM :: G3 Tech :: Body
door hinges
Post by billy-ray on Thu Nov 11, 2010 8:20 pm
are 4 door hinges the same as 2 door hinges
billy-ray
Street Cred: 13
View user profile
Re: door hinges
Post by Laguna Budman on Thu Nov 11, 2010 8:25 pm
Front doors I believe are but backs are different from what I can tell. Don't quote me on that. I can look closer for you if someone doesn't know for sure.
Street Cred: 4
View user profile
Re: door hinges
Post by billy-ray on Thu Nov 11, 2010 8:35 pm
id appreciate it i found some really nice front door hinges at junk yard thinking about gettin them if they will work
billy-ray
Street Cred: 13
View user profile
Re: door hinges
Post by Laguna Budman on Thu Nov 11, 2010 8:50 pm
Whatta ya mean about really nice? Only ask cause you can get kits for them at NAPA or Car Quest for about $8-$10 bucks per side
Street Cred: 4
View user profile
Re: door hinges
Post by billy-ray on Fri Nov 12, 2010 8:15 pm
but do the kits at napa come with the spring and that step lock assembly
billy-ray
Street Cred: 13
View user profile
Re: door hinges
Post by Laguna Budman on Sat Nov 13, 2010 9:26 am
No they don't. Do you need just the uppers then?
Street Cred: 4
View user profile
Re: door hinges
Post by Cdub74 on Fri Feb 25, 2011 9:40 am
Laguna Budman wrote:Whatta ya mean about really nice? Only ask cause you can get kits for them at NAPA or Car Quest for about $8-$10 bucks per side
My doors are hanging low. Would a pin kit fix that? Ive looked at the hinge and noticed that the roller is broken on both (driver/passanger). The hinge it self is fine, it opens and closes with no problem but just the door needs to be pushed up to close tight. Where is a good place to get them?
Cdub74
Street Cred: 0
View user profile
Re: door hinges
Post by The Dude on Fri Feb 25, 2011 10:29 am
First place I would check is the HELP! section in O'reilly Auto, Autozone, etc. for hinge kits. Usually they come with the pins, rollers, & any other related hardware. If you can wiggle your door up & down while opened then this is likely your culprit.
Street Cred: 48
View user profile
Re: door hinges
Post by Cdub74 on Fri Feb 25, 2011 10:46 am
just checked it out, thanks Rago!
Cdub74
Street Cred: 0
View user profile
Re: door hinges
Post by Cdub74 on Mon Apr 25, 2011 5:27 am
WOW! just installed the new pin kits, well just the drivers side since I found out how HEAVY these doors are I nearly killed myself,ha. What a huge difference, the door just swings open and shuts with one finger! The door striker loves it too, it was taking a beating before.
Cdub74
Street Cred: 0
View user profile
Re: door hinges
Post by Jedediah on Mon Apr 25, 2011 5:49 pm
Mmm my doors shut hard they seem like they dont have any extra play in em. Would the door striker and latch be my culpit passeger side striker stud looks like its gone a few rounds.
Jedediah
Street Cred: 4
View user profile
Re: door hinges
Post by pila on Mon Apr 25, 2011 7:59 pm
If the door lines up with the body OK, maybe the striker bolt on the door post needs to be moved a bit. I just loosen them enough that they can be tapped/moved with a small hammer, to find the right spot to let the door latch work right, and inboard enough to get the door closed tight etc.
2012 Donating Member
Street Cred: 17
View user profile
Re: door hinges
Post by Jedediah on Mon Apr 25, 2011 11:26 pm
I will give that a try tomarro. The passenger side seems to open stiff as well. I have been doing little things here and there. When i got my car the steering will was all torn apart and that was fun getting it back together.
Jedediah
Street Cred: 4
View user profile
