favorate previous gen. year
Page 2 of 2 Previous  1, 2
Re: favorate previous gen. year
Post by ' HARRY ' on Thu Apr 30, 2009 9:21 am
Very Happy I like them all. Especially the '64 and '65 A-body cars. Back in '78 when I was in the service, I had a '65 GTO ragtop. A real beater, but lots of fun. The car was driven out to California from New London, Connecticut by a sub sailor. It was so rusty from the winter road salt back East that the frame had stress corrosion cracks and a hole rusted in the rear bumper. I could open the driver's side door and stand on the door sill and bounce a little...... And literally watch the body flex so badly that I could see the gap in the passenger side door jamb move around! Had dreams of putting a rust free frame under the goat and restoring the body. But before I could do that, the car was tee-boned on the passenger side and totalled.
You can't see the body damage from the wreck in this photo, but here is my ragtop being hauled away to the wreckers.......
I pulled the low mileage '74 400 Pontiac engine and original '65 Muncie 4-speed before junking what was left of the goat and swapped them into a rust free '56 Chevy 2dr sedan body along with a '69 SS 396 Camaro 12-bolt posi rearend. Built up the engine a bit as well. Ran great.
Sub pier, San Diego, 1978.....
On the road leading to the WW II gun emplacements and the old Point Loma lighthouse, 1979......
Happy Motoring,
Harry
' HARRY '
Street Cred: 0
View user profile
Post by Limey SE on Thu Apr 30, 2009 1:47 pm
thats a time less look for these cars harry my buddy has this one here in town, but do i spy 3 carbs under that one ??
Street Cred: 60
View user profile
Post by Laguna Budman on Thu Apr 30, 2009 8:24 pm
Gotta be the 1962-1965 Chevy II Novas. Great lightweight cars, may look like a box but great cars. I have owned quite an assortment over the years and liked them all. I even had one make a movie debut once (Lakota Woman) my 4-door was in that one, they rented it from me for a month for the shoot.
Street Cred: 4
View user profile
Post by Hydro King on Thu Apr 30, 2009 9:00 pm
1964 Chevelle.
Hydro King
2008 Donating Member
Street Cred: 4
View user profile
Post by ' HARRY ' on Thu Apr 30, 2009 9:15 pm
Sweet ride, Hydro!
Happy Motoring,
Harry
' HARRY '
Street Cred: 0
View user profile
Post by ' HARRY ' on Thu Apr 30, 2009 9:19 pm
Laguna Budman wrote:Gotta be the 1962-1965 Chevy II Novas......
Very Happy The early Chevy IIs are great little cars, Budman. Lots of guys prefer the '66 - '67 body style, but like yourself, I prefer the more square lines of the '62 - '65 deuces best. In the mid-'70s, I had a '63 sport coupe and in the mid-'80s a '63 4dr sedan and a '65 wagon. The '63s were stock. The '65, I grafted and welded the front 3/4 of a '78 Malibu frame into. The Malibu frame went all the way back to the metal plates at the front spring mounts. Fit like a glove. That allowed me to cut back the spring towers, weld 1/8" flat plate in to replace them and swap in a 28" wide 500 Caddy mill. Also gave me better steering, disc brakes and stiffened the unibody structure. As you may imagine, traction was problematic. Wink
Best regards,
Harry
' HARRY '
Street Cred: 0
View user profile
Post by ' HARRY ' on Thu Apr 30, 2009 10:22 pm
Limey aka Maligoon wrote:thats a time less look for these cars harry my buddy has this one here in town, but do i spy 3 carbs under that one ??
Very Happy That's a righteous '55 your buddy has there, Limey! The rally wheels really set it off. What's under the hood?
Yeah, hard to believe it was 30 years, two wives, 5 sons and 3 grandkids ago when I souped up the Poncho mill and swapped it into my '56 Chevy. Wonder where the time went.......
I've got a thing for multiple carbs, Limey. This was a hand built setup I pieced together aboard ship in my spare time and I built the car at the auto hobby shop on base when we were in port. Worked out well, though. The '56 evolved over time. The photo below shows the 400 Poncho mill on the hoist just before I dropped it into my '56 Chevy. I kept the 12,000 mile short block stock except for adding a 286 degree Sig Erson hydraulic cam, Isky anti-pump up lifters and double sprocket timing chain. I replaced the smog heads with a set of '69 Pontiac 428 cop car heads. These had smaller chambers to boost compression and the big ports and valves. Installed Erson valve springs matched to cam and located a set of Dorman replacement rocker arm nuts that allowed valves to be adjusted like a Chevy. This engine was a tight fit in the Chevy engine compartment. I scrounged a set of '68 Firebird right hand center dump exhaust manifolds and ran the right hand manifolds on both sides. Most of these had smallish 2" outlets, but I got lucky and found a pair of them with 2-1/4" outlets. Increased to 2-1/2" right after the flange and ran 2-1/2" duals with Dodge hemi mufflers. Note Ansen 'cast steel' safety bellhousing and M-21 Muncie tranny......
The next photo shows the 400 Pontiac engine in the '56 Chevy right after I fired it up for the first time to break in the cam. Initially, I ran the '69 cop car Q-jet and moved the original 3-core heavy duty '56 radiator forward to the '6-cylinder' position to allow for the longer engine and OEM '74 clutch fan. Note OEM Pontiac chrome valve covers and '65 GTO power brake booster and master cylinder......
Tried every trick in the book, but couldn't keep the big Poncho cool. Finally had a huge crossflow radiator built at a radiator shop utilizing Grand Prix side tanks and a 36" wide 4-tube desert cooler core and added a combination of Pontiac and sheetmetal fanshrouding that I built for the Chevy...... Problem solved. Even had to replace the 160 degree thermostat with a hotter 180 degree to get the engine up to operating temperature
The last photo shows the engine after I installed the hand built Holley tri-power induction. I took a 1966 Pontiac tri-power cast-iron intake and adapted a set of new Dodge 440 6-pak carbs. These were the high performance carbs sold over the counter at MOPAR dealers back in the '70s. They were similar to AAR Cuda carbs in that they had the short square fuel bowls and the end carbs were mechanically actuated and had metering plates like the secondaries on double pumper 4bbl carbs. These were totally unlike the vacuum secondary carbs now available from MOPAR and they ran a lot better, too. To adapt them, I found a piece of scrap 1" thick aluminum plate and cut it down on a band saw to size. Then I laid out the holes and drilled the 12 holes that aligned with the Rochester bolt pattern of the manifold. I countersunk these and used stainless steel countersunk machine screws to fasten the plate to the iron intake. Next, I laid out the 12 holes for the wider Holley bolt pattern and drilled and tapped them. Then I laid out the 6 holes for the larger Holley throttle bores and drilled them using progressively larger bits and carefully drilling down through both the aluminum plate and the cast-iron carb mounting flanges below so that there was no mismatch, only smooth throttle bore openings beneath the Holley carbs.
Between the Holley carb base plates and the aluminum plate, I sandwiched 3 Ford 2bbl water heated/cooled carb base plates. I plumbed water from the front of the intake manifold through all 3 and from the last back to the heater core. The passenger side head of the Pontiac engine had a fitting pressed into the back of the head (coolant passage) that had a 90 degree bend and hose connection. I fitted a short piece of heater hose to this and connected it to the remaining heater core connection. This did wonders for drivability and cleaned up the top of the engine as well, eliminating the long run of heater hose that originally ran from the front of the engine all the way back to the firewall.
I adapted the OEM Pontiac mechanical progressive throttle linkage to the Holley carbs. It is painted red and you can make it out in the photos. The air cleaner is hand made. The oval filter element is from a 1970 Datsun 240Z. I made an aluminum base plate with 3 short 'D'-shaped pieces to raise it high enough above the carbs so that it wouldn't block the fuel bowl vents. It is sealed to the carb air inlets using rubber 'O'rings stretched over the 'D'-shaped air horns. The top piece is made from brushed stainless steel.
Ran great and jetting was right on. The only problem I ran into was fuel starvation when I kicked in the secondary (end) carbs. In the photos, you will note that I initially ran the fuel line in thickwall 3/8" OD stainless tubing. What I had to do is to remove that and fab a fuel log similar to those used in the early '60s OEM Ford 406 Holley tri-power setups. I built it from a piece of 1" OD stainless steel pipe. Capped the ends and drilled the front for a stainless 3/8" pipe nipple (supply) and drilled the sides for 3 (3/8") pipe nipples (aligned towards the carbs and connected to the fuel inlets with fuel hose and hose clamps). I welded all 4 pipe nipples in place and made up 2 stainless tabs with 3/8" diameter holes. These held the fuel log in place outboard of the carbs pretty much in line with the restrictive stainless tubing I had removed.
After this was installed, I pulled the gas tank and installed a new 3/8" fuel pickup and sending unit for a '57 Chevy dual 4bbl engine and replaced the original 5/16" fuel line with new 3/8" tubing from the tank to the fuel pump. I retained the OEM Pontiac mechanical fuel pump and along with the larger 3/8" fuel line and the added volume of the fuel log, no more problems with fuel starvation.
Note taller Mickey Thompson aluminum valve covers. These were a tight fit, but they just cleared the GTO power brake booster and firewall mounted battery box in my '56 Chevy......
Of yeah, one last thing. I was running a 3.73 posi rear along with a 2.20 low gear (close ratio gearset) in the Muncie tranny. With the lumpy cam, you'd think that this gearing would be just right. But the big Pontiac mill made so much low end torque that unless you were getting started from a dead stop up an incline or racing, 1st gear was nearly useless and either you took off in 2nd gear on level ground or short-shifted from 1st into 2nd right after taking off. So I swapped in a 3.07 highway gear and that worked out just right. Yes, contrary to all that I've been taught, but the big Poncho loved it even with the cam. Out on the road, if you eased into the throttle, you could run up to 90 MPH on the center 2bbl before the end carbs began to tip in. Top speed was around 138 MPH. Mileage on the open road cruising on level ground at 70 - 75 MPH in high gear was 18.5 MPG.
Happy Motoring,
Harry
' HARRY '
Street Cred: 0
View user profile
Post by JB2wheeler on Fri May 01, 2009 4:33 pm
That is very interesting and informative, Harry. Thanks for posting. JB
Street Cred: 21
View user profile
Post by ' HARRY ' on Sun May 03, 2009 2:10 pm
Very Happy Thanks, JB. Didn't mean to go on for so long, but thought I'd give enough detail so that if anyone wanted to build their own similar tri-power setup, this might give them some ideas. The limiting factor with 3 deuces is usually the intake manifold design. If you take a close look at the aftermarket tri-power intakes available for small block Chevy engines now of days, they have small ports, tight bends in the port runners and don't provide even fuel distribution. The OEM Pontiac intakes were a much better design, though. Both the tri-power and the 4bbl intakes. The OEM cast-iron 4bbl intake performed as well or better than aftermarket aluminum intakes of the era. And the tri-power was even better. I'd put them up against any of the newer intakes available today as well.
The only real drawback was weight. The OEM Pontiac cast-iron intakes were a high rise design and what Edelbrock calls 'air gap' now of days, as if that's new. So they were quite heavy, even with the separate sheetmetal valley cover. Much more so than a cast-iron intake for a Chevy, for instance.
When Edelbrock came out with their new high rise air gap dual 4bbl intake for small block Chevys a while back, I called them to see if they were going to make a similar updated performance oriented tri-power intake. But they had no plans to do so. Probably because they make the Carter AFB clone 4bbl carbs and don't make 2bbl primary and secondary carbs suitable to a tri-power installation. So little incentive for them sales wise, I suppose.
I may pick up one of their new high rise dual quad intakes and modify it to accept tri-power carbs one of these days, though. That would be great fun. And I believe it would put to rest the notion some folks have that a modern 4bbl will always make more power than even a correctly set up and jetted tri-power. If you have the flow and jetting right on the money, the key to unlocking performance is in the manifolding. For if you have a tri-power manifold that provides correct port cross section and flow, gradual bends and carb placement providing a nearly straight shot down the head ports (resulting in better fuel distribution than a single 4bbl intake), a correctly set up tri-power setup will generally pick up around 5% more power on top end over a dialed in single 4bbl setup on the same engine simply through better efficiency.
Happy Motoring,
Harry
' HARRY '
Street Cred: 0
View user profile
Post by JB2wheeler on Sun May 03, 2009 3:58 pm
I was under the impression that they had a complete Tri Power set up for a Chevy on one of their crate motors and available seperately. Maybe you should check again to see if they have, or will have, one for you. JB
Street Cred: 21
View user profile
Post by ' HARRY ' on Mon May 04, 2009 6:10 pm
Very Happy Thanks for the tip, JB. That's a a good idea, as new products are always coming out. I looked at Edelbrock's web site and at Summit's Edelbrock crate engine and intake manifold listings, but didn't see any newer design Edelbrock tri-power intakes. I'll keep digging around, though.
Offenhauser used to make a couple different tri-power intakes for small block Chevys. One is the 180 degree small port version that is similar to the Edelbrock. Still available new, but too restrictive for what I want to do. The other intake was a big port high rise 360 degree design (like an open plenum intake, only with a center divider plate running fore and aft down the middle of the manifold separating the right and left banks). I don't think these are still made and not sure how well they perform. I have an old Offy single 4bbl intake in this style I picked up at a swap meet some years back, but never ran. I could always do a little machining and welding and convert it to tri-power configuration. Might be fun.
Also visited Barry Grant's web site. They have a couple interesting tri-power intakes that they use with their own carbs. I'd like to get a close look at them, but we have no BG dealers anywhere near here. Not sure if they would part with a bare intake and no carbs at a reasonable price, but I'm going to call them sometime this week and see what they say about that.
Happy Motoring,
Harry
' HARRY '
Street Cred: 0
View user profile
Post by JB2wheeler on Mon May 04, 2009 8:01 pm
Harry, I just sold an Offy 2/4 cross ram intake. You might find it interesting. It can be seen at my site http://www.picturetrail.com/sfx/album/view/19847223
OR HERE TOO
Street Cred: 21
View user profile
Post by ' HARRY ' on Mon May 04, 2009 9:21 pm
* (Ooops...... gotta repost - can't get more than one photo per post for some reason - OK, here goes)......
Very Happy Sweet! Love the crossrams, JB. I have an Offy like that and a nearly identical Edelbrock here as well. Here is an Edelbrock XC-8 on a small block 400 Chevy (please disregard mismatched carbs...... They were for mock up to measure hood clearance).......
If I ever get wild and crazy with my '57, I have some rather fiendish plans for one of these crossrams......
' HARRY '
Street Cred: 0
View user profile
Post by ' HARRY ' on Mon May 04, 2009 9:22 pm
With a few mods to '50s specs...... Something like this......
Edelbrock X2 six deuce crossram for Pontiac......
' HARRY '
Street Cred: 0
View user profile
Post by ' HARRY ' on Mon May 04, 2009 9:24 pm
Edelbrock X3 six deuce crossram for early Chrysler hemi......
Wink Yeah, even us old guys raise a little cain every now and then,
Harry
' HARRY '
Street Cred: 0
View user profile
