door lock actuator?
door lock actuator?
Post by coreys73chevelle on Sat Feb 05, 2011 7:56 pm
ok not a car but its a G3 GM lol, my burbans power door lock switch on the drivers side wont do anything ( i replaced it and still no good) BUT i can and have been using my passanger door lock switch to lock/unlock my door and it lock and unlocks all of them INCLUDING my driver door. Do i need a actuator? seems like the only thing it can be? wiring all looks good.
coreys73chevelle
Street Cred: 8
View user profile
Re: door lock actuator?
Post by 1973 454 MONTE on Sat Feb 05, 2011 8:10 pm
take off the door panel and check to see if the connection is good.
2012 Donating Member
Street Cred: 26
View user profile
Post by Mcarlo77 on Sun Feb 06, 2011 11:12 am
The fact that your passenger side switch will operate the driver side lock shows that the actuator is functioning. It's got to be an electrical issue...possibly a broken wire or bad connection at the switch?
Street Cred: 17
View user profile
Post by The Dude on Mon Feb 07, 2011 8:48 am
Yeah I'm saying switch problem. Try swapping the two switches around & see if your driver side will work hooked up to the passenger side switch. If so, then you know your problem. Shouldn't be too expensive to replace.
Street Cred: 48
View user profile
