1974 el camino rear end questions
Page 1 of 2 • Share •
Ok when i bought this car, the guy who sold it to me said he put 373 gears in this thing. It is a 10 bolt Gm coorporate rearend per the dog ears on the bottom. The problem is its "howling" when you drive it. I really haven't had any problems with rear ends throughout my time with cars, and I'm a boat mechanic so the rear end usually stay in good shape on those...lol....my questions are:
1. What generally causes this? Gears? Shims? Bearings?
2. What parts are interchangable throughout the years? Can i take the guts out of one? If so what?
3. Would it be a better idea to but a different rearend per this site or craigslist or junkyard and just put it in there instead of messing with the one i have? If so, what reaends from other cars fit?
4. Should I go posi? Can i go posi with what I have? How can i tell if what i hav is posi?
any help would be great....I really love this site..........thanks in advance
Sam_snead01- G3GM Member
- Street Cred: 0
Re: 1974 el camino rear end questions
I'll try to answer these questions as best as I can.
1. Probably wasn't set in there correctly. Get some gear marker & verify this. Maybe you just have a wheel bearing that needs replaced though?
2. It's the 8.5 rear. All 1973-77 A bodies used this axle & interchange. Some were bolt on & some were C-clip style though so that's the only thing to worry about. Gears can also be found under some 77-96 Caprices, 80's model 442, Monte SS, & Buick GN, most 1/2 ton pickup trucks made from the 70's on up, & I believe that even vans got this rear axle.
3. Complete rear axles from any 73-77 A body or any 77-96 B body will swap in directly. Cop versions sometimes came with 3.42 gears, most others had highway gears. Some early A bodies had 3.31 gears as well & you might get lucky enough to find one with a posi. Whether or not you want to mess with gear swapping or rear axle swapping is your choice, but a rear axle isn't too expensive & is fairly straight forward to swap out. Four bolts, the E brake, & the brake lines.
4. I always recommend posi or some type of limited slip, but that's me. See 2 & 3 for answers to the posi question. Stay away from the Gov-lock posi in trucks as they aren't very reliable. I found this out first hand with a relatively stock truck. You can put limited slip in any 8.5 no matter what it originally had. Best way to tell if you have posi is to pop the cover & look. Not like it harms anything to change the axle grease. An old standby that works most times is to jack the car up & see if both wheels spin the same direction, but sometimes even with posi they will turn opposite from what I'm told.
- Street Cred: 48
There are two differant size carriers. One is for 2.55 gears and lower ((2 series carrier)) and ((3 series carrier)) is for 2.72 gears and up. JB
- Street Cred: 21
Since the 73-77 cars only ranged from 2.56-3.42 does that mean they all used the same carrier then? I never knew that 8.5's even had two different carriers, I thought it was just the 8.2 10 bolts. Thanks JB.
- Street Cred: 48
The 2.56 was a smaller carrier than ther other ratios. Hey, I only missed it by one number,lol. JB
- Street Cred: 21
Rago wrote:Since the 73-77 cars only ranged from 2.56-3.42 does that mean they all used the same carrier then? I never knew that 8.5's even had two different carriers, I thought it was just the 8.2 10 bolts. Thanks JB.
I actually added that Rago and yes there are two diff carriers
- Street Cred: 60
You missed the other number by one too JB, it's a 2.73. I have one of those laying around here if anyone needs one.
pila- 2012 Donating Member
- Street Cred: 17
what are the prices on those things over there? I checked ebay once and they were around 1000 bucks which seems a lot to me...
abajc3- G3GM Member
- Street Cred: 2
The one I have is an open 2.73, removed from my '75 . Code on the axle housing is
ACC 141 1
ACC 141 1
- Street Cred: 17
I've actually got three complete rears that would work. Still debating on which one to use.
2.73 open
3.08 posi
3.42 open
2.73 open
3.08 posi
3.42 open
- Street Cred: 48
I wish I had that 3.08 Posi to use as a spare in case I tear out my 3.47 posi. JB
- Street Cred: 21
Those 8.5 rears will take a lot of punishment though. Some guys run big blocks with those. Only thing I noticed is that the axle housing wears quite a bit where the OD of the outer axle bearings run, after beating on it for a few years. Then the housing needs the aftermarket C-clip eliminators with the ball bearings, to save the housing.
- Street Cred: 17
I have Moser 31 spline axles twisting 3.42 posi gears (or is it 3.47, always forget that last number) behind a 540 Dart Big M. I have not abused the rear TOO much, but so far it has held up just fine. Maybe this summer I might get a chance to put on my slicks and give it a real test on the strip. Anyone wanna drive it for me? I'm not a good driver. JB
- Street Cred: 21
Those slicks may do a number on that rear!
- Street Cred: 17
Similar topics» SOME ANSWER FOR ALL QUESTIONS
» Aircon questions
» Some weird questions..
» Polls/Questions for the RCF Universe
» Suggestions/Questions for Admin
» Aircon questions
Page 1 of 2
» Just some pics
» Old Photo Tow Truck
» NO...NO...NO...
» ~~Introduce Yourself~~
» 76 S3 in Franklin Indiana
» 4L80E..Reduced...$300
» Wallys 73 Malibu project
