1977 malibu Blower Motor won't stop
G3GM :: G3 Tech :: Electrical
Page 1 of 1 • Share •
Any Help greatly appreciated. As soon as the ignition is turned on the Blower Motor comes on no matter where the switch is positioned. Heater transistor? a Relay?
gpoetx- G3GM Newbie
- Street Cred: 0
Re: 1977 malibu Blower Motor won't stop
Is it a non air car?
Mmm. Mine does the same thing.
- Street Cred: 16
Thats how it works .Its part of the vehicle ventilation system.
ant7377- G3GM Senior Member
- Street Cred: 12
I always figured that. It never bothered me.
- Street Cred: 16
It's an Air car but I have never heard of one ever running constant. That's why there's an off switch.
gpoetx- G3GM Newbie
- Street Cred: 0
with my car its like this: when the ventilation is off, the blower doesnt work. when i put it on a/c or vent, it runs through all four speeds, but when in low speed, you can barely hear it.
if yours isnt working correctly, its probably the fan relay thats causing the trouble. its located on the right side of that a/c box under the hood (near the firewall). its only a 5$ part, so i suggest replacing it.
abajc3- G3GM Member
- Street Cred: 2
From the 1977 Chevrolet Service Manual:
"A" Series Controls - "The blower fan lever is located at the left hand side of the control assembly. The blower motor will operate as soon as the ignition switch is turned to the RUN position (providing the temperature at the engine thermal switch is at least 35*C (95*F). The control has three positions only; LO, MED, HI. There is no OFF position".
The OFF position I believe you are referring to is to regulate which air doors are utilized. Again, according to the manual "The position of these air doors determines if output air flow is from the heater purge outlet at OFF, the heater outlet with slight air flow from defroster nozzles at HEATER, A/C outlets at VENT, A/C outlet only MAX & NORM, heater, A/C and defroster outlets at Bi-LEVEL, or the deforster nozzles with slight air flow from the heater outlet at DEF".
There...everything we all needed and wanted to know (and then some) concerning our temp controls. No need to thank me...HA!
Mcarlo77- 2012 Donating Member
- Street Cred: 17
Similar topics» EML + 1 motor yam
» leaving if bullshit dont stop
» 1977 malibu Blower Motor won't stop
» FAQ: HVAC Blower motor only works part time, or stays on
» Write-Up: Blower Motor Control Module Replacement
» Just some pics
» Old Photo Tow Truck
» NO...NO...NO...
» ~~Introduce Yourself~~
» 76 S3 in Franklin Indiana
» 4L80E..Reduced...$300
» Wallys 73 Malibu project
