headliner
Page 5 of 5 Previous  1, 2, 3, 4, 5
Re: headliner
Post by Fishgrinder on Mon Aug 22, 2011 1:49 pm
As I'm about to install the headliner in my Monte I have some questions:
1. Can I just attach all the bow clips and put the panels on later, or should it be done at the same time?
2. Is glue only applied in the front and rear?
3. Do the seat belt retractors go under the headliner, or do they clamp it against the roof. If the latter, is it enough to cut holes for the bolts, or should i cut a big square for the retractor?
Fishgrinder
Street Cred: 0
View user profile
Re: headliner
Post by 1973 454 MONTE on Mon Aug 22, 2011 1:59 pm
glue goes on all 4 sides
headliner first than everything after.
2012 Donating Member
Street Cred: 26
View user profile
Re: headliner
Post by abajc3 on Mon Aug 22, 2011 4:26 pm
attach the clips first, than start to glue it all around. use spray on adhesive, otherwise youre gonna have a mess. it also stays soft fore a short while so you can still make some adjustments. dont worry about spraying it on the seats etc., it will peel off easily when dry. dont worry about using too much either, just make sure to glue only so much material that it gets covered with plastic moldings at the end.
it really isnt hard to do, you just need some patience and feeling for details.
abajc3
Street Cred: 2
View user profile
Re: headliner
Post by Fishgrinder on Mon Aug 22, 2011 11:27 pm
Thanks for the answers. But what about the retractors, question 3 in original post?
Fishgrinder
Street Cred: 0
View user profile
Re: headliner
Post by abajc3 on Tue Aug 23, 2011 2:11 am
unfortunately i dont remember that. maybe some of the guys could take their cover off and snap some photos. i would do that, but iŽll be at the university for the next 2 weeks
abajc3
Street Cred: 2
View user profile
Re: headliner
Post by 77mali on Tue Aug 23, 2011 5:38 am
When I removed mine it looked as if the liner had been cut after having been installed over any openings that required clips or things such as the rear seat belt retractor covers. Wish I had some pics of it with all the trim off before stripping it off, sorry.
Street Cred: 14
View user profile
Re: headliner
Post by Mcarlo77 on Tue Aug 23, 2011 8:47 am
I believe you are over-thinking this. All I know is, when removing nice headliners that I am trying to preserve, I always remove the retractors first as there is always at least one edge that is pinched under the retractor. You've got at least 1-2" of overlap with the retractor trim pc, so you don't need to be precise on the cut. If it were me, I'd glue the headliner in place and do the trim cut afterwards. Start with a smaller cutout and increase the size as needed to get the retractor in place. I've got a used headliner I could show you if that would be of any help.
Street Cred: 17
View user profile
Re: headliner
Post by Fishgrinder on Tue Aug 23, 2011 11:25 pm
Mcarlo77 wrote:I believe you are over-thinking this. All I know is, when removing nice headliners that I am trying to preserve, I always remove the retractors first as there is always at least one edge that is pinched under the retractor. You've got at least 1-2" of overlap with the retractor trim pc, so you don't need to be precise on the cut. If it were me, I'd glue the headliner in place and do the trim cut afterwards. Start with a smaller cutout and increase the size as needed to get the retractor in place. I've got a used headliner I could show you if that would be of any help.
Would be great If you could take a picture of the area. But in a way I got the answer in your post, as I wondered if the retractor had a function of clamping the headliner down, and thus tightening it against the roof in the sides.
Thanks
Fishgrinder
Street Cred: 0
View user profile
Re: Headliner
Post by Mcarlo77 on Wed Aug 24, 2011 8:09 pm
Here is a pic of a cutout for the retractor on the driver side (looking at it from the front). If you look closely, you can see the shadow line where the retractor trim pc covers the opening. As you can see, the cut doesn't need to be that precise. Honestly, I don't think they intended to purposely pinch the fabric down with the retractor.
Street Cred: 17
View user profile
Re: headliner
Post by Mcarlo77 on Wed Aug 24, 2011 8:12 pm
I'll be out tomorrow searching for stuff. I'll take a pic of a headliner with and without the retractor in place and note how or if it's pinched in place.
Street Cred: 17
View user profile
Re: headliner
Post by Fishgrinder on Thu Aug 25, 2011 11:29 pm
That picture was very good, I think I've got a good plan on how to do it now. Thank you Mcarlo77!
Fishgrinder
Street Cred: 0
View user profile
Re: headliner
Post by Biomedtech on Wed Aug 31, 2011 10:51 am
Anyone by chance have a sewing pattern for the headliners? I found some carbon fiber that is bonded to a cloth backing, thought about doing up a headliner with it. If not I'll just take my old torn one to the local seamstress and see if she can "reverse engineer" it. Laughing
Biomedtech
Street Cred: 2
View user profile
