77 Cutlass Race Weight
Post by oldstofty on Thu Apr 21, 2011 7:11 am
Just weighed the 77 on all four corners, time to buy new springs. It weighed a little less than what I thought but thats a good thing. 3430lbs. Any one have any other ideas to lighten it up? already has Glass bumpers, 2 fiberglass race seats, No rear seat, fuel cell, aluminum wheels, and some rust Smile
oldstofty
Street Cred: 3
View user profile
Re: 77 Cutlass Race Weight
Post by The Dude on Thu Apr 21, 2011 8:21 am
Damn that's good news! Big block or small block?
Engine lightening >>> aluminum heads, intake, water pump, carb. Composite valve covers, lightweight starter.
Aluminum radiator.
Take out any & all heater/AC stuff if you haven't already. That stuff weighs a ton.
Might check for fiberglass doors, trunk, & hood. I want to say Unlimited had that stuff for Cutlasses.
Get rid of the inner fenders or get some plastic ones from a 73 if they will fit.
Lose the power steering & power brakes.
Tubular control arms.
Lighter battery like an Optima.
Cut out big A$$ beams in your doors. They are called crash bars for a reason, but if you primarily use this as a track car then you could be saving a lot of weight just by losing them. I want to say that I've heard close to 80 lbs can be lost cutting these out.
I've been thinking of a way to get rid of the bumper shocks all together & haven't come up with a good solution. Knocking out all four of them should net you 50 lbs by my guess. You already solved the heavy bumper problem. Bet that's where a lot of your weight savings came in.
Street Cred: 48
View user profile
Post by oldstofty on Thu Apr 21, 2011 9:20 am
BBO with Steel heads aluminum intake holley carb, 3 core heavy radiator. Heater, AC, and power brakes are gone. already has plastic inner fenders. Suspension gets to expensive to quick lol. still has the crash bars. does have an 8pt cage. Bumper shocks are gone.
oldstofty
Street Cred: 3
View user profile
Post by Limey SE on Thu Apr 21, 2011 9:28 am
also Rago VFN fiberglass has the trunks and stuff way cheaper than Unlimited
Street Cred: 60
View user profile
Post by oldstofty on Thu Apr 21, 2011 9:31 am
If i cut out the door bars, would i have to pin the windows up? do they interfere at all with windows?
oldstofty
Street Cred: 3
View user profile
Post by Limey SE on Thu Apr 21, 2011 9:35 am
If I remember the windows will still work with out the crash bars my buddy took his out as well for his car to lose weight
Street Cred: 60
View user profile
Post by The Dude on Thu Apr 21, 2011 9:40 am
Doesn't appear to have anything at all to do with the windows. If you take off your door panels & look into the door, you will see the bar up against the outer skin. It looks like a big flat piece of double plates that goes from the front of the door to the back. Not 100% sure of how you would go about cutting them out, but I have heard of people that have performed this mod. I have thought about doing it myself.
Street Cred: 48
View user profile
Post by oldstofty on Thu Apr 21, 2011 9:41 am
ok maybe ill give that a try. I should have the car out next week or the week after to do a little testing will post up pictures for sure. car hasnt been out of the garage since the middle July when I put the motor in lol
oldstofty
Street Cred: 3
View user profile
