Pair '74 Lagunas
Page 2 of 2 Previous  1, 2
Re: Pair '74 Lagunas
Post by 1973 454 MONTE on Mon May 09, 2011 7:32 pm
i have 2 complete monte MOONROOFs over here in cleveland ohio.... Beer
Street Cred : 35
Post by Mcarlo77 on Tue May 24, 2011 10:12 pm
Limey wrote:
Mcarlo77 wrote: the white one has the large qtr window partially covered with a sheet metal patch on the exterior and the triangular padded insert on the interior sail panel.
I would check the VIN on the white one then for that sounds like a Malibu that was converted to Laguna front HMM maybe
F.Y.I.: Checked the VIN number on the white '74 Laguna (as well as the black one). Both VIN's check out as being original Lagunas. Guess it confirms GM used whatever they had on the line at the time to build these cars.
Street Cred : 64
Post by pila on Tue May 24, 2011 11:38 pm
When I removed the vinly top on my '74, the big quarter window had sheet metal panels welded in there to make the little opra windows, and a lot of bondo to blend it in. Of course I stripped the whole body with paint stripper, removed all the bondo, and went from there.
Post by Laguna 74 on Thu May 26, 2011 5:44 pm
MCarlo77 I sent you a PM on the grille.
Laguna 74
