TH350 Transmission leak
Page 1 of 1 • Share •
Hi, I've got 1973 Malibu with auto TH350 and I got leak that I can't find solution for it. On the driver side there is a shaft (linkage) that comes into transmission which shifts gears (from P do D etc.). I've got oil dripping out of that spot. It’s probably something easy to fix but I can’t find solution to stop the leak. Did anyone have this problem? Any help is appreciated.
Thanks
Thanks
rogal_tx- G3GM Member
- Street Cred: 0
Re: TH350 Transmission leak
I dont know, but I have a feeling you will have to tear down the whole transmisson to put in a 10 cent rubber seal. JB
- Street Cred: 21
JB2wheeler wrote:I dont know, but I have a feeling you will have to tear down the whole transmisson to put in a 10 cent rubber seal. JB
yeah, that just might be the case. if im not mistaken, that shaft can only be removed from the inside of the housing
abajc3- G3GM Member
- Street Cred: 2
Man, I hoped to avoid that but sounds like thats the only solution.
Thanks for help
Thanks for help
- Street Cred: 0
You don't have to remove the shaft to change the seal, but you do have to have a specialized tool for removal (looks like a socket with threads on the outside). I haven't seen the tool at regular places. It shouldn't cost very much to have that seal changed at a tranny shop. If you do do it yourself be very careful... one tiny nick on the seal and it will continue to leak.
Pdawgie- G3GM Member
- Street Cred: 0
Thanks, I will try tranny shop first just because I don't have that specialized tool and it's probably not easy to find either.
- Street Cred: 0
Just get an oil & filter change, and tell them "oh, by the way, change the selector shaft seal while you are in there"
The TH350 is easy to work on actually, and I've rebuilt a few, but it does require some special tools.
pila- 2012 Donating Member
- Street Cred: 17
Similar topics» Transmission oil seal leak
» GSI with oil leak
» FAQ: Transmission Shift Modulator
» Carp Disease - Infection and Transmission
» TH350 Transmission leak
» GSI with oil leak
» Just some pics
» Old Photo Tow Truck
» NO...NO...NO...
» ~~Introduce Yourself~~
» 76 S3 in Franklin Indiana
» 4L80E..Reduced...$300
» Wallys 73 Malibu project
