Emergency brake help ASAP
Post by wokrdan AKA BU Balls on Sat Jun 04, 2011 1:45 pm
So I've disconnected everything from the chassis that connected to the frame, but I can't figure out for the life of me how to disconnect the e-brake. Anyone who can help, please respond ASAP as I would like to get the frame out this afternoon. Thanks.
Street Cred: 2
View user profile
Re: Emergency brake help ASAP
Post by ant7377 on Sat Jun 04, 2011 3:13 pm
Disconnect it from where? The rear has these little clips near the control arm mounts pull those off then disconnect it from the plate inside the drum assembly. Once you see it you will understand. The front gets disconnected inside the car then slide it out from under the car. You will see that under the dash at the endof the e brake pedal.
Street Cred: 12
View user profile
Post by wokrdan AKA BU Balls on Sat Jun 04, 2011 6:05 pm
I found my Haynes manual and got it. Thanks.
Street Cred: 2
View user profile
