Frame OFF!!!
G3GM :: G3 Tech :: Body
Page 2 of 2 Previous  1, 2
Re: Frame OFF!!!
Post by wokrdan AKA BU Balls on Thu Jun 16, 2011 11:03 am
So I got my body mount bushings in the mail, but something tells me they're not the right ones. I got the '72 convertible set.
Street Cred: 2
View user profile
Re: Frame OFF!!!
Post by jrb75 on Thu Jun 16, 2011 12:11 pm
Uhh ohh
jrb75
2012 Donating Member
Street Cred: 0
View user profile
Re: Frame OFF!!!
Post by Jedediah on Thu Jun 16, 2011 12:38 pm
The hole diameter looks the same. The old one's probly compress when the body is on them and the new urathane one's wont compress so that is probly why they look different. I am not sure just a gues hope some one can tell me if i guessed right.
Jedediah
Street Cred: 4
View user profile
Re: Frame OFF!!!
Post by 74Malibu383 on Thu Jun 16, 2011 2:21 pm
Jedediah wrote:The hole diameter looks the same. The old one's probly compress when the body is on them and the new urathane one's wont compress so that is probly why they look different. I am not sure just a gues hope some one can tell me if i guessed right.
....Maybe. However, they look a lot shorter as well....
Street Cred: 20
View user profile
Re: Frame OFF!!!
Post by bigredlaguna on Thu Jun 16, 2011 4:33 pm
The parts place has 73-77 GTO/Lemans stock style bushings listed.
http://www.thepartsplaceinc.com/ocatalog/part.asp?VID=6&YearList=1977&Search_Keyword=&CatID=&curpage=8
Found it via a Impala SS forum where they discuss body mounts for their cars
http://www.impalassforum.com/vBulletin/showthread.php?t=255855&highlight=body+bushing&page=6
I'm inclined to think that the Impala/Caprice kits would fit more directly, but I haven't been able to find dimensions for the body bushings any where. Someone on some forum I read made there own out of hockey pucks.
Street Cred: 31
View user profile
Re: Frame OFF!!!
Post by 1973 454 MONTE on Thu Jun 16, 2011 4:45 pm
HB2132Z
(1973 - 1977 GTO/LeMans) BODY BUSHING KIT (KIT IS MADE OUT OF RUBBER WITH STEEL SHELL INSERTS. TWO OF THEM ARE SOLID RUBBER PLUGS & THE TOP CAP BUSHINGS HAVE STEEL WASHERS MOLDED INTO THEM JUST LIKE FACTORY. THESE REPLACE ALL GM NUMBERS: 330942 (4), 457915 (12), 330955 (4), 377801 (2), 6271662 (2) & 330951 (4) - ALL BUSHINGS HAVE THE GM NUMBER ON THEM) - 28 PIECE KIT
looks like the 330951 is what is on your rubber
Street Cred: 26
View user profile
Re: Frame OFF!!!
Post by pila on Thu Jun 16, 2011 6:36 pm
Mine are the stock rubber type, from the Parts Place like I mentioned, and should fit '73-'77 A bodies and El Caminos like mine. They may have the hardware too, bolts etc. I used the old hardware, since they came out easy and shiny .
Street Cred: 17
View user profile
Re: Frame OFF!!!
Post by wokrdan AKA BU Balls on Fri Jun 17, 2011 10:40 pm
I'm almost tempted to just use these. There's a few of the old ones that are still in good condition, but I don't know how they'll match up with the new ones.
Street Cred: 2
View user profile
Re: Frame OFF!!!
Post by pila on Sat Jun 18, 2011 9:30 pm
I would be inclined not to mix old with new, since it's liable to stress the body a bit when they are torqued down. I guess you could shim the old ones to match the new ones (?)
Street Cred: 17
View user profile
Re: Frame OFF!!!
Post by Laguna Budman on Wed Jun 22, 2011 10:08 pm
I'm back sorry so long. Been workin on car. Finally painted and puttin back together. Did they work? I hope so cause thats what I used and it worked and its all bolted down and painted. Let me know
Street Cred: 4
View user profile
Re: Frame OFF!!!
Post by ss2323ss on Mon Jul 04, 2011 11:00 am
Looks good !!! Ever wonder why they call it a frame off and not a off the frame !! lol Very Happy Smile Shocked
ss2323ss
2011 Donating Member
Street Cred: 0
View user profile
Re: Frame OFF!!!
Post by pila on Tue Jul 05, 2011 1:28 pm
I know what ya mean. I call my Elco project a "body-off" , which seems like a better description. If the whole works was up-side down, I would call it a frame off !! Very Happy
http://s561.photobucket.com/albums/ss52/steelybill/El%20Camino%20resto/
Street Cred: 17
View user profile
Re: Frame OFF!!!
Post by ss2323ss on Tue Jul 05, 2011 5:10 pm
You do good work !!!! Good luck
ss2323ss
Street Cred: 0
View user profile
