Front windshield molding
G3GM :: G3 Tech :: Body
Post by 1973 Buick Century on Sun Jul 17, 2011 1:27 pm
I have a leak in the windshield. It has been around long enough where it rotted out the passenger floor pan and someone used what looks to be silicone for a kitchen, to seal the leak. They have it everywhere, the body and trim. No
The problem is, when I was removing the trim, I monkeyed it up. I removed all the other trim without any issues but the windshield trim put up a fight. My question is, is all the chrome trim the same for '73 to '77 A body cars? Or is it just Buick and Olds, while the others use a slightly different design?
1973 Buick Century
Street Cred: 0
View user profile
Re: Front windshield molding
Post by 77mali on Sun Jul 17, 2011 6:31 pm
This is on a Chevelle, the set up is 3 piece and the sides swoop @ the bottom...I think on 73-77 coupes the the front windshield and the roof rails are the same but not 100% sure. Hope this hepls.
2012 Donating Member
Street Cred: 14
View user profile
Post by 1973 Buick Century on Sun Jul 17, 2011 7:22 pm
Sure looks exactly what I need. Everything from the light fold in the middle and the swoop at the bottom. The top piece already had waves in it from the last time someone was there.
Also I cracked the windshield when I was pulling the trim. I was needing another away way since it was a cheep replacement (pulling apart inside itself) but I just did not want to do it right at this stage without a job as it is.
I read that coupes and four door/wagons are different than one another. Anyone know if that is true?
1973 Buick Century
Street Cred: 0
View user profile
Post by bigredlaguna on Sun Jul 17, 2011 8:22 pm
Coupes are different from sedan/wagon. The windshield is more upright on the sedan/wagon.
Street Cred: 31
View user profile
Post by Limey SE on Sun Jul 17, 2011 8:52 pm
Looks pretty dam close to me but will be your call 73 buick
Street Cred: 60
View user profile
Post by bigredlaguna on Sun Jul 17, 2011 9:12 pm
I'll bet the hollander exchange numbers are different. IIRC, the windshields themselves have different part numbers.
Street Cred: 31
View user profile
Post by jerry46765 on Sun Jul 17, 2011 11:00 pm
Four door and wagon is different than a 2 door coupe. I had a windshield & chrome from a 4 door and it was longer than a coupe.
Street Cred: 11
View user profile
Post by bigredlaguna on Sun Jul 17, 2011 11:22 pm
So the rake may be the same or very close, but the sedan windshield is wider between the A-posts, is that correct Jerry?
Street Cred: 31
View user profile
Post by jerry46765 on Sun Jul 17, 2011 11:56 pm
It was longer vertically like 2". Windshield and all the trim is different lengths. I probably still have the 4 door stuff since I couldn't use it and had to find another windshield.
I don't remember if the cowl or the top is different. It was quite a few years ago.
It should be a no brainer in a salvage yard.
Measure from the top down on the windshield in the middle.
thanks -
Street Cred: 11
View user profile
Post by Limey SE on Sun Jul 17, 2011 11:58 pm
ok now I see what your mean red and Jerry
Street Cred: 60
View user profile
