TH350 Transmission problems with shifting
Page 2 of 2 • Share •
Page 2 of 2 •
1, 2
Re: TH350 Transmission problems with shifting
74Malibu383 wrote:Front seal?
and tips how to replace it or check if thats whats leaking?
rogal_tx- G3GM Member
- Street Cred: 0
You have to pull the tranny and take the torque converter off. If it's leaking, you'll need a seal puller (T-shaped tool with hooks on the end) then you can tap in the new front seal. Make sure it goes in square.
74Malibu383- G3GM Enthusiast
- Street Cred: 20
Maybe the seal in the shifter selector shaft is seeping, where it goes through the case. Had that problem once....
pila- 2012 Donating Member
- Street Cred: 17
Page 2 of 2 •
1, 2
Similar topics» Anybody got same problems?
» FAQ: Transmission Shift Modulator
» Transmission oil seal leak
» Carp Disease - Infection and Transmission
» TH350 Transmission problems with shifting
Page 2 of 2
» 73 CHEVELLE SS PICS
» 75 cutlass
» Just some pics
» Old Photo Tow Truck
» NO...NO...NO...
» ~~Introduce Yourself~~
» 76 S3 in Franklin Indiana
