what brake boosters work 5 5 1
Page 1 of 2 1, 2  Next
Post by billy-ray on Sat Sep 03, 2011 6:52 pm
ideally it sounds like an 11 inch booster is the best but what are the differences and which ones fit our cars
billy-ray
Street Cred: 13
View user profile
Re: what brake boosters work
Post by TWBouska AKA Wooderson on Sat Sep 03, 2011 9:37 pm
id go with the astro van hydroboost swap honestly
http://www.carcraft.com/techarticles/ccrp_1105_chevy_astro_van_hydroboost_salvage/index.html
Street Cred: 6
View user profile
Post by TWBouska AKA Wooderson on Sat Sep 03, 2011 9:38 pm
i plan on doing it on on my car whenever i finally get time to hit the junkyards again
Street Cred: 6
View user profile
Post by billy-ray on Sat Sep 03, 2011 10:31 pm
im not swapping my steer box i just put that thing in and when those things start to leak forget about it
billy-ray
Street Cred: 13
View user profile
Post by TWBouska AKA Wooderson on Sun Sep 04, 2011 2:15 pm
im going to be upgrading my box pretty soon anyways, and yeah it does suck when they leak, im just going to pull two and have an extra ready to go when one fails
Street Cred: 6
View user profile
Post by pila on Sun Sep 04, 2011 6:43 pm
That hydro-boost would help with the close clearance I have in my Elco project. The left rocker (valve) cover is only 5/8" from my booster.
And not only the Elco, but my old '85 Caddy beater has crappy brakes, even with all new parts in the system. It needs something drastic, and that set-up looks like the answer.....
The 11 inch seems to be the most common for '73 to '77 GM..
2012 Donating Member
Street Cred: 17
View user profile
Post by TWBouska AKA Wooderson on Sun Sep 04, 2011 6:49 pm
i think hydroboost is the way to go man, so what if it leaks? thats what they make degreaser and pressure washers for. i can run whatever cam i want and not worry about brakes being effected..and yeah the clearance helps too like Pila said, although i have no problem with that currently
Street Cred: 6
View user profile
Post by billy-ray on Sun Sep 04, 2011 8:30 pm
1,000 dollar price tag no thanks ill work my leg out and go manual brakes before i do that
billy-ray
Street Cred: 13
View user profile
Post by jerry46765 on Sun Sep 04, 2011 10:51 pm
If the engine stops turning, you have no power brakes.
At least with a vacuum booster, you get a couple pumps when the engine is cut off.
Why reinvent the wheel?
It isn't like your braking stopping distance is better.
And do you really want to use engine power for an easy brake pedal?
Thanks -
Street Cred: 11
View user profile
Post by TWBouska AKA Wooderson on Mon Sep 05, 2011 9:19 pm
good points, but i still stand by my point, i dont care about engine power too much personally, my motor has plenty of get up and go and honestly how much power is it really going to "rob" me of? not enough to notice.
Street Cred: 6
View user profile
Post by jerry46765 on Mon Sep 05, 2011 10:47 pm
That's the great thing about hot rodding, you can do what you want.
If you look on new trucks, they are going to electric vacuum pumps for brakes... no longer hydro...
I run an 11" vac booster and a canister to cover the camshaft.
It's simple and it's worked forever.
Thanks -
Street Cred: 11
View user profile
Post by oldstofty on Tue Sep 06, 2011 8:36 am
I run manual brakes and steering on my car, but its not something you would want to use as a daily driver
oldstofty
Street Cred: 3
View user profile
Post by The Dude on Tue Sep 06, 2011 9:18 am
How bad is manual steering on our cars? I got a manual box to swap on, just contemplating whether or not it's worth the hassle. FWIW, I have dealt with manual steering on an older A Body & it wasn't too bad. Got a good workout trying to park, but nothing too major.
Street Cred: 48
View user profile
Post by jerry46765 on Tue Sep 06, 2011 10:36 am
With manual steering, less caster and narrow front tires will make it easier to steer at low speed.
In a newer car, they are almost impossible to drive w/o power assist because of the amount of caster added to self-align the front wheels straight with little or no effort (for our driving safety).
Also depends on scrub radius in the front suspension as to the amount of effort involved. Wide wheels with big offsets in the front wheels will also make it a monster to parallel park.
Manual steering could be done with slight alignment changes and narrow front tires with zero offset wheels.
But the original question was brakes...
Street Cred: 11
View user profile
Post by The Dude on Tue Sep 06, 2011 11:26 am
LoL, yeah I know. Sorry about pirating the thread Billy-Ray. Just wondered how much worse a G3 was than a G2.
IMHO as far as brakes go, our cars are good enough from the factory if you get the larger rear drums from a 76-77 car & slap on a set of good pads up front. If you are running too big of a cam to run power brakes, then Jerry has the right idea with a reserve canister.
Didn't the Olds diesel powered cars have some sort of belt driven vacuum set up? Could be an idea if you run across one in the salvage yard.
Street Cred: 48
View user profile
